The Missile
Car  Clio Sport 182
The car started life as a standard Australian delivered 182 non-cup purchased so I could get out on the track and improve my skills. Pretty much as soon as I got it I semi-stripped the interior, put in some AST’s, added a race seat, ED cams, lightweight wheels and dz03’s along with the other peripherals that go along with a basic setup (pads, camber bolts, bushes etc).
JRto3ri7oyHGnEYL3kc2tTwNQRJLtI1dtWAK9N5hbjo3lmZxOyqDv6GsppURhMQDxAX3vXQl1JiNEQbZhbSaKNAaoqBfYaR1.png
84ou10JyBvFVb295fyKsubDAH8b8myK26rgvWrt1__fZpZn_HlucEPaOWDBHNOTETsx5lgspBRMDy1vYDsj1yr9MSid-eupC.png
After a few track days I had the bug and decided to put a diff in along with a helix clutch, lightweight flywheel, decat and ktec intake. I decided that a gripper was the way to go along with a shorter pinion and crown-wheel. I was in the UK for work so loaded up the suitcase.
V8eNJP01PNB_8Or08l8dFvlagH0xttlb29zIl1t21RpKhm457skEQByv5y65hEOYacBS8e36YlQDz_swzFu2zPimve17EpAH.png
Around this time my wife had also moved her business into a new office so I decided the office should have a workshop attached to it in which I could do some spannering (my neighbours had endured enough of me working in the apartment garage!). Moved my tools in and I pulled the engine in preparation to install the new goodies.
ervQNsrRuL3sLHGYuolF-ErHPPvQQ0_LtR4mtv7qAz7iVcuvCRQN8CGVauczSDRJZfkM4wtDTv_93OWu5y4pPk0mxfjVNWgw.png
rdlWc6WC88qzrwAlcYUPWWiYZFydsSYLbBTl3dZBBqybZoJpGyfZMjzRV-sahRXA9duS4veyRLaBi9CKcWVCmTZw_noeMTa3.png
I also decided to strip a little more of the interior.
Kymn_1SQWgKEOFKMD5Hk9PDa_vCEpCzyvHAuVfuwOg2CRlvVRoo9YN2yskrIKMjXvFYCYB55756II7wVGbL-E6Ib3k8StnDd.png
While at it I removed the ABS, installed a 4 port master cylinder, hardlines and a bias valve.
Wo97VJky6sirMBMgzi-3Hr975X6O5LJoBuHDDmdRuDd4eG7lJR-4RvqD8pbBu-BVsMr7ezmcNJ1DMIbSQYmKc_dmpoHurB0P.png
uuGe0GQ0PTXK_fwY2ERV2ZmMwG-WdBzrI-ocyN0DPck2sc5oO5T1L3s84rGOn3sEBgqwe27vD2XHBJjRzpjfMksHYTmCqWM3.png
Next came a lightweight screen heater having removed all the factory parts.
HfXXFl65E3BizRTEHLKhlTvb3duT3kAr11CDG1miJfig723pKVeNs8nIoW6eUfAo8J3UOATYb-i210mcLVaCRORSZOeHqsUA.png
I also thought some cold air ducting would assist so gutted a couple of headlights and installed a vent.
oDkZDcA0g1vLS8A5fRKt8vL1ogcIWilxXhTygAknylum60S1BQSrrRQDID3Qjh6ENSQekmBVMe72HICBfH8xx8_2tHPN1MCT.png
With everything installed and all tar removed I painted the interior.
U7z1CoayEfcYzbGiyTol7sW4c1p0KmkYT1dymYA0YeL3LVtVt6XHU---DfpWWkdEP-6EGqk95ldJoWmMoz2qh8WK95JHHr51.png
Decided a cage would be a good idea so had this installed - 6 point national spec cage.
5JX0Q3wm_EQuLVMDxVQETgGEFXLIZ6OYmpKFImB8geWHGcgHWbKEHR_bJqgsaA_Xumrqd7RLphkzNo9x0ZzNLAM3-X3_KLeF.png
JioG_2a-EDAJcjiaCv2XdOwKe1TbWdlJLFQ8Rmb-Kx2FEODK5kg9gJCtBtIwwnWAPvtEeKAn9oUEqnOntOkWSdgB4WQ0bCf_.png
Welded up an exhaust for a little more bark and also welded in a pure motorsport bearing kit on the front wishbones.
Z30DoMaxRrsX_mWPUE1FApPpjB0J0jNRRBByZXnarKLsGwGCofFJxTNGKa4p2BwJtpyI_aVuPNt8xhLb95NhF_YTI8qibuFY.png
Ut9NSAiMhBjxTBzW5yP-8ESP56ePTdSgEzOFYRgLVfNKWbfROk5FJxhtJ3_l80Ac4NJSf9N4dlyS_q7NHrydcn6_4MuJ3Bl0.png
At this point, fully loaded with the cage the car weighed in at 931kg.
Time to get on track.
lJ-e6zghv1_QCyiA9MoL3S2pMBEFpiX4-fW6A35pcidkuEynRJzIbFzC1Cf0AcEbO2dYN2H_x_fSfo3BUhOEMIfFirCNL9bC.png
V4oFpqoA7gTewduuP7tbL9DLmXf-lKsFzxMrgK06E9cpzgn7QHRWdFEAE2ymIO1SZ0x6Jg_uz8vN0_UuZnDuicXR8m1V81IU.png
Back in the shop lightened the boot and door skins.
xDQ5v8W6lJL60u8Kk_L8f2m35A0M8mzHMoeaZNHOHrRe6OeF1X-hhar2836hXXv0cjs1a6VPOU7ezK_lVHiKw21ce3D39fka.png
k4bZDAITskz8Ux66UBFVwGlUTx-VF41UJs10TmEAQY1SrXNCtWdiiNRpYA0Mez5vuicRpnaSiQQfn2zn3nUmvDGNIDPNcCNd.png
After a bunch of fun days out I had an issue - finding 3rd instead of 5th down the main straight had catastrophic consequences with the gearbox and clutch being destroyed and one of the mount lugs on the block being torn off!
I started thinking about what I should do & I could not get the idea of putting a 225 engine and box in out of my head. I scoured everywhere but could not find anyone who had successfully done this in a Clio 2 (this was 2013) so I bit the bullet and bought a written off Meg.
U5hGnkZg1RIHqrL9Vhr485W94wXKwFv08j0BBFpOe8KG61Crr_v8a-jDZG-0WmrP7SCpYzCk8tGcPDfScEj4JWg_Q5C9FUjT.png
With no reference I thought I would lift the engine in and see how it fit. To my surprise it pretty much dropped in, with only a slight notch in the chassis rail required for the gearbox.
SlVMXkL9TW1vVAl1PQT6msFMFZwKGt9XyuI6ZBUhm0bf0Xgtey66kVvHMotwxOYnX_nHTOpE_bvJtKUsdmh-3aQEK55lzSxR.png
lAL3Qvlw-WqOaf7iPasv275ZwwquRXRQ1y0MQY6JHV5EHGA1G8ahXSpknzwhVI8OmbpituucjqVwFmQC2zvCihK2v0JkOGX8.png
Decided the engine needed a little more support so went about making a front and rear dogbone and mount.
Vnp_JsZFngeLnR6N7yTY6sh-ndH3_x6wyBZZs7T952xbly3mywVVKGtfjO76PBuT0-SYd55afL78dOGLl17QF6L3B9h5AE4P.png
nDJ3LgyekWLpgqt4yvSngaA2YMQ5x5xl3rH6lpwmgge4DVE2l5S9c2KHUfXfzjy2PtLD3W825lW3Qqs6paTr5ntqaVRHMkXI.png
F9F0cL7UhUbYz6fytctC_PET1Plqz82Dfmm8ptaKgkEet7fAcXERDqbSzWRxNJH4IdoMJclBJEr0gF2ko06wu6za_9flh4jC.png
Thought a proper pedal box was the way to go (also needed a hydraulic mc for the clutch) so bought a wilwood pedal box with adjustable bias and tilton master cylinders and made up a plate to go in the factory location.
7ttSazdJj9_y_jyAepU6ymLBepngftoM-cjc7OZqgJ1vR-wumzryf07ZAp_0m2ZnaGIEyYQDKUvwMASdZ4B-Ei98p-AKuNlz.png
dlYQ0maB2AR-3lvCoKMR4D4Kc3LEo2dZKzob2tGhSZnE3WU4JnMjshL5wFhJci8K4NU8t5QZum-3YdysRa5W_ZLf9NFmCbeA.png
9GtMIusGbiNPQNa2QMRzH4vLsRoPc3w4xFM0iWgdUYtSGNua0-kWLikmTRzQqiMkCtVesV4RPdIzWc0rGOfRRE1htpQ8JNef.png
Installed the reservoirs and new lines.
i5AaAfJLQafOYpg6k81FlE2fqwUTfIabKUBJa57prSTkSfxAHJVUl_qU3x5fyrNf1CVpGJ9yqdVqWe9sJX1k4fo3BmvOYi6m.png
R1XIM-dDJFvc5t7bAJd834smNK_SQQLZPMGfLMRzxmn0pKmZZkv7_CCBaeiK_s5VFaxzH8XWGgoSH2IyBntLb_TwPLLMPcdq.png
QBWmRcfUVX9_QCQLbEHxERYb9-SghnxJRx3RfGrPV0_J6iDxVr6JzapmCwxFPtOaAI_56yBiLU2y96VTm7QfTcERFcR8D99C.png
Thought a larger turbo and an ecu was in order - ended up with a borg warner 6258 and Motec M84.
QEDouOXGDt7fPizRYUSbqntIHNr-NIBTvmrnC6j0ebJELt25zOC_bV6AY6GJ_f4QsUB9I_0jUtBNSWSQb_M6poTd8rr2p-7u.png
Sent the engine for building with a bunch of new bits for the inside (rods, pistons, bearings etc). Retained the clio head as I heard it may flow a little better.
Needed a cam signal to run sequential injection/ignition so installed one.
ccuEyZ7VJ0G4q9XCvh-nx47ppxxlE3jsGUsbXvtJFzv1Q2OUIemjgAJzcGk38N3BdWeDZXueG1Jb7NHOnTTeEjkFvdXx2Y6e.png
Upgraded the brakes to scenic 300mm discs and Meg Brembos.
daFt4YpXXbaZPEUIxhw9R8vyYjVwbc6zPkyvRpln4kWvV_dKXCdWjoUbUnmoTEEcdGDoz0i3XJ3Xnw8MdWfTuz3ily3hkhxy.png
Installed a large intercooler.
ypbvgU4JExjtjBPlP3pYYlpqh27ljFh9iGuBkhOic3RmzPKPOBEhzAenzyTobwXiZsZcPL36ChYmjpY2_5RkAw-luu-XitKJ.png
dmdhF_k1U7I78xDZzX2oriIcsG-Qqf1eJToetnciDPTjgOPpWjcweh__V6zy3HtMoF2RrwyLrBNuDjxpUu1kIJgokJE5nPKW.png
A new intake manifold was required - this was a good opportunity to learn a few more skills so bought a tig welder and went about making something up. Unfortunately most of the photos of this have gone AWOL.
3IO--IgDsHuC3v3m_3i-NdAqny6PQ2yuNTcB3W2sGsOhtScCJXb_pmYZjwm8rLi6mzyyWjxZr6157A5o-6Ugvkn0h-Rh3VCH.png
q4MwGhm-rZY6HsOwBzqBn9EN-GsGSRjG6oLM7KusF1qOku0lyY8x19k8iyYoDadwrNdBNv9V8O1rs9LTYkGh9idsZhuM-Vl6.png
It was time to bolt the turbo on - running a log manifold I put it all together.
26hiNq_7hj6HxMt8_CMr7uyanramBqyCRIurGOL1DYz2WMmTOo6s4Yj9_vKW0TBMfDj3LSLYKg8kygBReyqHBhgebyd7Y1jL.png
With the engine back in I welded up some 2.5 inch intake piping. Also had a new fuel rail made up with a return and installed.
n-c38imTnGsZmfO6zkcUHU5bArLbHYqni1obEbgoAS8zZC332Pdk377gyfiGPMyzHGQldJ8y6Vif68tnyd6Htu9XS4ivgfht.png
Time to wire. Having never done this (or most of what I have done!) I labelled everything for easy reference.
WwXkCsZAcapFw8UkM7WyhdEuiAl2IGEjxS8nCCNtvqaTMJyfsZyTPJEj7wxewnTFzZF6iEptW_ovPGPcWKy6rdliFLxvgMIT.png
Welded a bracket for the Motec and igniter and connected everything up.
PonpQ5dYGJAMHvwNWIYmrSenfawIRGU_t-2g-JYUBVO6rpEWPHIHUdqzCuLhWxREbrYaiPW_g7StSgHm0UmpQjzVMAbYjYgX.png
Installed a remote oil filter and oil cooler.
3gh_1aTJDqCEQd9qaZNv1NWViOAT7Bdr3-xJKAMIyiMLgRC5LSnPmIobRBaPhQwDrTd5r1QYpwJdZhSjr1OyNDitt2JECT-F.png
Welded up a 3 inch dump pipe for the turbo. Very tight!
LDeKEogbsERFHqlYw1lCHBflESR01BMoVVZGDl_KRfSWbcO-uX4RN8cBk7z2Q6Xqb6eWTwg3NXyUMO7rRiZH486Us5mAV7p6.png
I bolted everything together, along with some custom driveshafts and a gripper diff in the meg box and gave her a wash ready for the dyno.
ZnWurwy5ljF8wdqSBqy7tdI4BwCPpOryI39Pc1l7yFX8UJrXYvx4szKrcd653dWJ4qOab45Pf8vN2r5JEjMqmgzigAmHYOAx.png
tTq_0Phg--DgpxtVro9RAduXnD9x0NTGejPNhqj-LWKK3NMPKmyGana33HrtzE_HB4XnmZ0ejmXoG2aL6juvXuyLSzf6A_vi.png
I was pleasantly surprised that the tuner got the car running and it all worked! Ended up making 345hp at the wheels running 22psi.
Hzhy5eiQZx1rlpo9WEGybyyZfKDCWEUEnZUVwcXPHaQRc66TB2n1l8b9NMbOsLHdlwlgZggTt3PRzXApUQj9AeaPLog7zyAj.png
Before heading to the track I finished up the interior and put a racecapture unit in running a tab dash (very cool bit of kit!).
Stx8KY8FEFktNmiKkSvywSITAXxDwe8vlZJOadNT5WWzIFivLW_EsbZPubYzZ-MyTM8ERpGi70g1ZujjhB7FkxcI0dxeAeo6.png
vO9Y8OGQvLTnLsk76Xzj3205aXiK6DkyO7PuXLtzrXpET0CyZn6gPq_9U1hUH-93wt3OtHheJHcXS6oHRLkeDBfz5UqojpBU.png
H61H6D4BqSbFh5tDNcSRuZXJSRUxt66yiBq780r-fLRB0A6yrO2nvdsEBOVViattfFsv9fsG39W-CsBOgo6pFbczS6K_bCMG.png
I read a lot about roll centre adjustment on here so made up some lower control arm ends and pins.
hGVswdOeNLO_1e7dNM07yAE9wV3d6sGkJN5e4iCZN0ygrZOoXRmRNac7pakso8u6SxbDx8MCAov8vWKyr5Fy9-_BdelQdsou.png
I took the car out on track a few times. Everything worked as expected and it was a hoot to drive. Unfortunately I had an issue. When I took the head off this is what I saw.
zs2n_zh0vgZ62bhapL9Q-G1MuUQZ26cl_ySvi0lNFqRuMAN0fKJg_puMNV-Ce8mHbntmLPiaA9UVXaK9etxVFOzhBEXaUpnl.png
So while the engine was off getting rebuilt I decided a brake upgrade was needed.
Ordered some 325mm 2 piece discs (compared with clio and scenic discs).
Y2wE3L5wyIPIEGa1FcnI4TElmP5hUKyD4_cW7HOEn8lYtycMC0lbGTBrN5k37VXEDGVRoO80yTcK3_7M-YBqXM4A_pjsgRnA.png
And some Alcon calipers (this was the largest setup I could get under a 16). I machined up some mounting brackets and made up some lines and got them installed.
5g8lZzi_srGJQAkaisnluc-KPYKL1l1KCvZBnremr6UlFLnP_Rv_DUHBZ6T-hjkmknFv66MS8peCkIEM-6nhgZYRyAuxswsE.png
0Cp_My_s59of2n6LdJtl8f_nMfdmuZs7z71vO4523lPhU32KksB9S6CcjkYVXKf1N2A7bwr7-EUdqqHSCVL1tgRtXvNPNB3U.png
eIA3D2R8vrSw_SLQbTGlidqhEgP2YZmpFYf7xRsHO5ZsckAmo-oPhkzE2MU3JBn_W-4-vWtEeNpo856XYhnhngfCta6OMajr.png
With the engine back I went about getting it in. Having decided to move to E85 I upgraded the lift and main pump and also put some 1500cc bosch injectors in.
And the initial result was 386hp at the wheels.
e8asmXYlpEtSLAM0Wi3Iq-HQULvNkScNCnyjcMdUUFxCH2yPG9GQaPnzfmDmpx-zgqomV-revBBcn2MaYWkZdB7pmg1qFy_3.png
After some more work we landed at 399hp at the wheels.
317cb6Uo0ovRvJCTPdrX-UuwQrP2PpTbukgibcO-a3au_w_3f1LhWfp_VhTs54AIRqiuM3xL1wtZo6g7M4j3wPm9PMrDQF4V.png
Decided to try some slicks in an attempt to get more traction.
XkO-f5uhDlxhaUOT5lGUKa9EIaalKrIwUM4DMVY7vmEnTAsHD99itJIUc5ONwDmy9CDExUkLu6QXoHXH7pQ3mYLVwroGkv53.png
After a few more days on track I decided to install some PMS rear beam bearings.
KTP-Ew5X3nnIiuVM_6hiJlVJnQl86Xm8iAYfZ_1PH6P5S5RLHrDrYo_8JJnmnD1zdmj_HAUU-mwYG9gYVpC46pcIjeEFDbE9.png
Then after a couple more days out I decided I needed more grip. The slicks just were not doing it so after some research I decided to emulate the FWD time attack cars. 255’s on the front and 225’s on the rears. The guards required a little work to fit.
YeHIbNCTKz0cK6SCF3TZxqGpQqgx3Z-04QtQ-UjZtosNWu9Lo8lDwF50jdSjHJDn5SUfWSh1Y0g8qq6ZyjyW-w3U23WGiXRm.png
Also added a splitter on the front. Amazed how much difference it made.
zEQJsIiXS3O7xbWVYnImEO5mbXTeN48ezN1JAQOQGRlb5ehtDOCBfUukio2_mR5qimLa2yENW60As82mDkfugQNfjodwBIEO.png
At this stage, with the car pretty sorted I decided it needed the looks to match the go. So, after a lot of work making it fit I put a s1600 kit on and added some 255’s on the rears to match the fronts (and some spacers between the rear beam and hubs to get it wide enough). Front inner guards required some cutting and welding as did the rear.
tJ6SXMGDbHYe3zFjCb7XYX2xgrIt0JJpUDgiCbDr0GVmhnys-xthX1Skb67ZLjkue9iMXRjwdQy_pdZWr1KtwN6Z6kOMWv2s.png
jcoaVds-e3gWSECrrI3n3hsZvBKb279XQ-q8VKqL7wJdOvfrDCDdqcmoUz_yd7Brukmb2w5EpfHUzNrh4mHPWfAV_zSiJgjx.png
p3bQRD38kRbSVcoIBwVAGBP2uR5Mi_WYAMxNlym6-9Nsn_tekxKpAwSnxbxgxNjccPE3iHHEmnlhuMkumvxyniRWh3UZFFc0.png
With the kit on I decided that Glacier White was the colour I wanted so I sent it off for paint. And this is how it came back.
YjECt-jxXhYcDqmq4EjE-mtOkLcqXJjCX06cHmseVZkdPrSyoY8aOW-6D065Z12tnXSpN-fnr5u3AaE6n7E6L89RjAWaGbUD.png
zrBJyHm8HS1I2giSF-LlSQeuWKnAQMiC2whiF99YmU00K2HkaMdfwjNb2e06iNx48LrKbRgYjpFxBcdT329yvh9_uh1dDpqw.png
And with everything bolted on ready to go.
kXDj2hWHQq1iS_sm7z7QcIY7dx1Rx7E2d8ZgpNUkMZs7PufP5qbpUf15z0Gs2a2Rii9S4aQ8PESYj-dgv4YQtP1EdML_GZIc.png
NnIlT8Dt-Cn1s5HWCb1Qkp07TvQwCt4aoYYOgr43A3WxEIjSRmKmfyMquV-yp5B_Zx5lP0gv2KRa7w5_K_eBtZbGU_4eHJVd.png
3XCOJTzf8faDeXY4MtVVQN1A5Fd8M-4ztsHpCarkm_Alb_P-bAHlTeSXhbP01Y00H-ukpyViMmvIyZclqM7cb6mHYiUBNN52.png
R2Vjzody3E193uJedbc1IwrMy8Y2m8tEolE7svwM3DZUxxTPR5XQsWrEnFIK8uI0LVzcb7A4byolYaLo4cCBRJzQ7z7j4bSj.png
oP02ahG82NzEa87aoYQflQ20pD9CMCR5e9PoOl7Xe50fFVF8Z-PigWAsyxw6JMCLIuXs-KtRKPdsSM1c1GpRuWIUlPweuaDo.png
Have only had one day out in it and aside from a collapsed rear wheel bearing (suspect I may need to upgrade) it is brilliant. Can't wait to get back out!
Spec as it stands as follows:
Engine/ECU
Megane 225 Bottom End
Clio 182 Head
Wossner Forged Pistons
PEC Forged Rods
ARP Crank Shaft Stud Kit
MLS Head Gasket
Borg Warner EFR 6258 Turbo
Custom Engine Mounts
Custom Aluminium Intake Manifold
Ph1 Clio Throttle Body & Pedal
2.5" Aluminium Intercooler Piping
600x300x76mm bar and plate intercooler
K&N Air Filter
15 Row Oil Cooler & Braided Hoses
Aluminium 2L Catch Can
Bosch 1500cc Injectors
Custom Fuel Rail
Rising Rate Fuel Pressure Regulator
Aluminium Swirl Pot
Braided Fuel Lines
Walbro Lift Pump
Deatschwerks 350 Main Pump
Motec M84 ECU
Custom Cam Sync Sensor
Bosch 221 Ignition Module
Megane COP Coils
NGK BCR8ES Plugs
Stainless Steel and Iconel Valve Set
Cast Exhaust Manifold
3" dump pipe & straight through exhaust
Alloy Radiator
Samco Hose Set
Suspension/Steering
AST 5100 Coilovers
AST Adjustable Strut Tops
Pure Motorsport Wishbone Bearing & Stiffening Kit
Pure Motorsport Rear Beam wishbone kit
Powerflex ARB Bushes
Whiteline Rear ARB
Rear beam to axle spacers and Camber Shims (-3 deg)
Bump Steer Correction Tie Rod Ends
Roll Centre correction lower ball joints, pins and spacers
182 Cup Front Hubs
Electric Steering Column & Rack
Brakes
Wilwood Brake/Clutch Pedal Box
Tilton Master Cylinders
Custom Main Brake Lines
Braided Flex Brake Lines
Alcon Calipers
Custom Caliper Mounts
325mm 2 piece Discs
Pagid RS14 pads (front)
Brembo HC Clio Rear Discs
Pagid RS42 pads (rear)
Driveline
Megane 225 6 Speed Gearbox
CAE Megane 225 Shifter
Gripper Limited Slip Diff
Lightweight Flywheel & Helix Paddle Clutch
Custom Drive Shafts
Body & Interior
Super 1600 body
Custom Front Splitter
BYC Rear Wing
Perspex Side Windows
OMP WRC Seat
OMP 6 Point Harness
Full National Spec 6 Point Roll Cage
OMP Steering Wheel
Custom Switch Panel
Race Capture Telemetry (and Android Dash)
Lightweight Windscreen Heater
Aerocatch Bonnet Pins
Wheel & Tyres
17x7 ET20 JR Racing Wheels
Dunlop DZ03 255/40/17 (front)
Hankook RS3 255/40/17 (rear)
Wheel Stud Kit
Wow. Awesome build mate! Loving how it looks now, that splitter looked something serious before.
Looking forward to updates
[emoji7] speechless looks amazing! I bet it's a handful to drive!
With the big rubber on it is surprisingly manageable. Before it was tough and I was seriously considering going back to a built n/a engine.
"The Missile" makes sense now!
Brilliant job on the car. However, I think the office having a workshop was a stroke of genius :up:
Yep, agreed - having the tools and space made the project much more pleasant.
Wht a bloody fantastic build this is!
I'm rather jealous! Although, I'm not jealous at the bank balance you've lost creating this stroke of perfection!
Quality
Cheers! I look at is as an investment in my sanity and pleasure. I spend a fair amount of time working so the mental health gained from building and driving this thing helps keep me able to do that. I have never added up what it cost (and never will!) but doing the work yourself definitely saves a lot - regardless of what other cars I have I can see that this thing will always have a home with me.
Not sure how to edit posts on here but the wheels are in fact 17x9's.
Sent from my SM-G955F using Tapatalk
Wow some amazing home spannering on that, congratulations sir! You need to get a camera fitted so we can see how it goes on track.
Great inspirational car! Nice job, +1 on the camera fitting, would love to see some action and see how it goes.
Nice one Cam, met you at the Nats. Will have to get passenger laps next time round [emoji106]
Impressive!
399bhp at the wheels! What's that at the flywheel, 450?
Something around there! Was a handful on 205's but much more manageable on 255's now. Actually makes me think about more power!
Cheers! Should be out next Thursday and Friday so will try get some footage then.
If anyone wants to mount a seat nice and low - effectively an inverted version of the OMP mount which goes down in the middle instead of up on the outside.
That explains the weather in the photos! I'm guessing there's not too much to be improved upon, so build updates will be minimal? Have you got any more photos of the roll center mod?
Haha, yeah, it's a nice part of the world!
Control arms are about 40mm wider than stock and also shift wheel further forward (more caster). A little over engineered but better that than a failure!
Bolts are not threaded into the hubs. No issues thus far but will consider if required.
Oh, and I'd like to think it is getting close to done but I am sure there are a bunch of things I will come up with!
Video from today at Wakefield Park.
Got black flagged for 96bd. Quick trip to the exhaust shop and I was back with a new resonator and just over 90db! Also collapsed another rear bearing - have ordered the upgrade stub axle/disc/bearing from PMS. Ordered their rear beam stiffening and sway bar while I was at it!
Great video, sounds and looks like it's bouncing around a lot loosing traction? What settings are the dampers on?
