Pop and bangs after cams fitted
Sj1782
Car  Audi s3 8p
I had 197 cams fitted to the 182 last august and since then it always pops and bangs above 3k with tapping the throttle and gear changes is this normal? Sounds good just hoping I'm not doing damage to the engine!
It's lasted this long lol
Can't say I've ever read that happen though. Was it mapped to suit?
Efi mapped it, I've probably covered around 10k miles I just gathered it was normal with the cams? Also my cat is still fitted
Just a quick video of it.....
Never popped/banged before the map and cams
Unsure it was already on when I bought the car, all I can say is it's very loud! No rear back boxes, just a cat and centre box fitted.
Can't say that I'd live with that sound, but it's definitely different. I've never heard one sound like that before.
Mine with cams and ITB's used to pop it on the overrun after it was mapped last year. It started doing my head in so some more advance and fuel added low down sorted her out a treat.
Sounds great!
If Chris mapped it, it won't be doing any damage. Rather a characteristic of the cams.
EFI mapped it in, probably do it for all their customers. You can have it corrected, though
I'm ashamed to admit I love pops and flames on the Evo
that actually sounds better than a pop and bang map!
were the cams times specially?
I would live that on my daily.....
Clioturbo carried out the work [emoji102]was timed up to his method
I really like my Ktec supersport. Decat and unsilenced centre, 2.25.
There was a miltek for sale on here, 200 ish. Might be an option?
Same setup that @Niall has just fitted.
What are pms systems like? I would need the exhaust modifying as I have a sleeve welded onto the end of the cat
Only ever had one on a phase 1, never heard one on a 182
The quality and fit no doubt will be spot on. Not cheap mind.
I have 197 cams in mine and there is no pops and bangs. Generally that is something that is mapped in or something is wrong with the timing.
BTW i have a PMS exhaust on mine and its lovely bit of kit, can't recommend it enough. It is quiet tho, just a bit louder then OEM.
