WIFI Boosters?
Mr Burns
  Swift Sport
I'm a technophobe who's having issues connecting my smart TV and phone to the internet in my room. I'm constantly losing connection as it appears the router is too far from my devices, but I was told today that if I bought a WIFI booster box it would solve my issues.
Can anyone confirm this or better still recommend a specific booster?
You don't need to run wires between the homeplugs. They use your houses wiring. You just plug one in beside your router with an ethernet able. Then plug the other one wherever you want it
Daniel
  Whichever has fuel
Like Ste, I am a techno r****d.
Can you explain a bit more?? I have a very old house with 12 inch thick walls so my wifi is really hot and miss some days. These look ideal but not sure how you'd wire them up??
You just plug it in to the wall, then plug an ethernet cable between the homeplug and the router. Then plug the other one where you want internet. You can then either plug an ethernet cable from the second homeplug to your pc (or whatever) OR you also get ones that have wifi on the second homeplug meaning you have a very reliable wifi repeater
Mr Burns
  Swift Sport
So I'm assuming I just plug one homeplug in near my router which is connected to the router, and plug the other homeplug in my room?
  RB Clio 182
Our wifi boosters are great, just plug it in the wall no wires needed, we could get zero signal in our bedroom before and i couldnt connect to the internet, its now full bars and we never lose connection.
Mr Burns
  Swift Sport
What booster have you got mate?
charltjr
Powerline stuff is great if your home wiring is suitable, I used to swear by them but they're a bit slow in the current place because the wiring runs are much longer than in previous houses I've been in. They still work fine, there's just a significant performance drop off.
I use a £15 Netgear range extender now to overcome exactly the problem you had and it works great.
https://www.amazon.co.uk/gp/product/B00NIUHAG6/?tag=cliospnet01-21
Personally I'd try powerline for any application where performance and latency is important to you, but buy from somewhere like amazon where you can return them no questions asked if they're not quite right for you. For streaming telly, hooking up a mobile etc I'd keep it cheap and cheerful. It's one of those situations where there's not really a right or wrong, it's just what suits you best.
R3k1355
They have issues with old wiring and going between different ring mains IIRC.
I don't know how you'd go about figuring out what plugs are on what ring main but you might get some performance boost moving plugs around all onto the same one???
Mr Burns
  Swift Sport
Interesting... We live in a detached house so I'd be surprised if other signals are interfering, but it could easily be the case!
andybond
Unless you are miles from another house , I would very much doubt you are void from another signal. WiFi search on your phone. I would be very surprised if you dont pick up several others.
JonnyK
Honorary Member
  500 Bhp Golf R 7.5
If i was to buy a wifi extender I would make sure it was wireless AC, not the outdated N
Starlet_gt
  VW T5.1
I use powerline adapters. Signal is brilliant and it means the WiFi in my garage is not far off the speed I get in the house.
Sent from my SM-N910F using Tapatalk
charltjr
Again, depends on your circumstances. AC is overkill for a lot of people as their broadband connection won't even come close to saturating an N connection. Sure, if you're doing a lot of big file transfers etc the extra speed can be welcome and the extra range can be too. Horses for courses. Moving up to AC would have doubled the price of the range extender and it would have been useless for me.
Powerline can have issues with some types of RCD in the fuse box especially when the signal crosses over to another ring, which is why I recommend getting them from somewhere with a good returns policy so you can give them a go and see if they work for you. When they do work well, they're brilliant.
JonnyK
Honorary Member
  500 Bhp Golf R 7.5
I guess it all comes down to if it is solely for internet purposes, or if you have a home network and file transfer speeds etc.. are important. Which to me they are.
MrBlonde
Anyone using a booster with the Sky Q box/router?.im looking to get one to work with my Sky router,im only in a flat so guessing doesnt need to be to fancy.
  Listerine & Poledo
Another vote for powerline.
The only times it isn't a better idea:
1) old wiring
2) if you have more than 1 main board. The Powerline signal only goes as far as your....'consumer unit' (?, someone electrical will correct me here).
ethernet > wifi
Paul172sport
  Sunflower Ph1
My garage is about 50m from my router and I want to pick up wifi down there.
What's best to boost/extend the signal?
I've mains power but it's run off the main fuse box but on it's own circuit and via a separate mains power cable down the garden.
Will the plug in ones work for me??
Yeah should work fine. Buy it from Currys or something and if it doesn't work you can take it back. Pretty sure it will though
