K20 powered 172
Chambers_RS
  Clio 172 Cup&Leon K1
Chambers_RS
So finially In is the parts from PureMotorsport :smiley:
As some may have guess the PMS ITB kit was amongst the parcels :cool: fitted with 330cc injectors and the throttle cable conversion kit.
CatCams also made it in 421 flavour
And the posh PMS radiator, been drowling over these for ages 😂
Other bits I’ve ordered
CamBelt kit and genuine dephaser pulley
I ordered another PMS coil pack bracket as I sent the new one too@Christopher. when he brought my RS2 as my old one had snapped.
I’ve also order some new tools but only the timing kit has arrived from Pure.
So yeah the plan is cam and ITB now but I’m looking for away to make it different to the normal ITB engines out there tho.
Oh I had to put the ITB on loose for look tonight too.
Chambers_RS
Had poke around the engine today and found a an oil leak at the back of the head.
Manifold studs are wet in oil, fresh oil sitting on the manifold flange and the back of the block is wet too.
Probably will orders gasket set and change the top end for peace of mind, feel another order from Puremotorsport coming on 😂 so easy ordering from Nick.
Chambers_RS
Collected my engine crane today. Not the best time with the snow but only day I had free to get it.
Running out of room in the garage now lol
Also ordered some VHT paint and brought a new expansion bottle from work.
Chambers_RS
As the weather is meant to be nice this week I’ve pushed the CUP out the garage to try and make some progress on it and organising the garage.
Also made a start on removing the seat and cage, as some times you need to take a back wards step to go forward :tongueclosed:
haimsey
  ph2 172
Looking forward to seeing the progress with the itb’s! Do you still run the stock oil pressure sender/switch? I fitted my braided take off and there’s not enough wire on the plug for the stock one to reach to put it back in.
Chambers_RS
Cheers bud.
Yeah stock oil pressure switch. You can unpick the loom and move the plug/wire pretty much anywhere you like upto the alternator. Mines pcliped upto the thermostat housing.
Rubicon_
  L110, RS6, Westfield
How do you get on without blowers inside mate? Ive got mine looped like yours but regret doing it now with the state of the windscreen on a cold day cant see a thing.
Chambers_RS
Tbh I haven’t done a wet/damp track day in it yet. I’ve done a cold frosty morning which was fine. I don’t use it on the road at all, I do dread to think of the day I have a wet track day as I’m plastic windows too and don’t have a roof scoop or air feeds into the cabin lol
Is yours really bad? I do have a t7 heater bolted in but not wired up lol
haimsey
  ph2 172
Thanks, started to unpick it but it’s so fiddly. Gonna do ac delete at same time I think. Have you got the sender for the gauge mounted on the thermostat housing too?
Chambers_RS
Yeah I do actually. I’ll try and find a better picture for you to see.
Chambers_RS
Finially had half hour to split the gearbox and engine.
Gearbox, clutch and flywheel off.
Engine on the stand.
With it on the stand I started to look abit closer at a few things I was worried about.
Crank seak leaking maybe.
And oil around the exhaust manifold gasket
Had a delivery of a few parts from Renault dealer and Puremotorsport
Probably need to look at ordering more from Renault like head gasket and crank seal or bottom end gaskets maybe
Chambers_RS
what sort of power are you after with TB and cams?
I haven’t really look at what figures it’ll make 200 maybe?
Tbh I don’t really care. As long as it’s mapped well and great fun to drive and takes abuse that’s all that matters to me really. I’ve built it to be battered at track days and maybe race next year so As long as it don’t break every track day I’ll be happy.
