Flob
Hi all,
Recently purchased a little 182, MOT is at the end of the month so figured I should have a look underneath to see what kind of state it was in.
All mostly looks ok(ish), leaky rear shock, snapped hand brake cable (looks fun to change), and a newly developed clonk from the font end... I seem to have a real knack of buying tight cars which fall apart and fail within weeks of my ownership.
Upon inspection I found a bodged up, cable tied rod which attached the subframe (front of the lower arm) to the chassis/inner wing. It appears that the retaining bolt has sheared so some kind sole has repaired with cable ties. So my questions are as follows:
#1 is this an MOT fail
#2 is this a common issue
#3 can the car survive without?
#4 repair suggestions? Thought about drilling the bolt out a little and welding a new stud in place, using a nut in place of a bolt. I suspect the bolt snapped for a reason and will not be coming out any time soon.
Other side to compare:
