ilya's 172 #BECAUSE_RACE_CAR
RuskiWeldFab
  Clio 172, RS4 B7
I saw some brake cooling ducts on Back Yard Civic which bolt straight onto the brembos. Directing air to the brake pipe and caliper. I know it's for brembos but the same idea could be used?
http://bycdesigns.co.uk/index.php?route=product/product&path=67_17_64&product_id=106
Yeah I saw that. Will try this first see how it works. The problem is, there is literally half inch between chassis and wheel on full lock. So ducting can only go under the car. And not a big diameter. I already tried to fabricate some ducts out of planting gutter pipe by Bering and flattening it. But don’t like it.
1985michael182
What about something like 1/2 inch alloy box section with reducers on each end to fit the ducting onto to? Run it down the side of the chassis leg?
Maybe? I'm needing a solution to this problem also, so looking into different ideas
RuskiWeldFab
  Clio 172, RS4 B7
September 2018
Fitted new heated windscreen (after I smashed the other one with in first 30min on track. Always check your bonnet pins!!
Cartek pdp can only supply 30amp max in dual Channel mode I decided to not use both channels for my screen (4 buttons) but fit 2 fused 30a relays. + PWM controller for speed control to my single wiper.
And on Monday went to Rockingham. What a great day with Trackobssesion! Apart from brakes (still having either pad knock back or boiling fluid or air in the system) nothing failed! Worked flawlessly. Best lap 1:34
RuskiWeldFab
  Clio 172, RS4 B7
few pictures from Rockingham on 03/09/2018
next outing 25/09/2018 at Bedford.
RuskiWeldFab
  Clio 172, RS4 B7
in the paddock
R29TJR
  2005 RB 182 Cup
I absolutely love the camera view from underneath.
Amazing to watch. Love how you can see the tyre move.
RuskiWeldFab
  Clio 172, RS4 B7
Whats your brake proportion valve set at? Have you had a play around with it on track?
I tried few positions. Found best one is 2 stops from max pressure. As far as I can tell. (Lever forward.)
Does the pedal feel any different when you run less pressure to the rear? Today I was having a play around and found I had more consistent pedal with less
RuskiWeldFab
  Clio 172, RS4 B7
Hmm I am not sure actually. Don’t think I spent enough time tinkering with it to understand. But with no pressure at rear the rear end was very lively at hard braking. Felt light it was getting very light and had a pendulum effect.. sort of. If it makes sense.
@pule333 I see what you mean, the rears would be trying to 'overtake' the fronts as the balance would be thrown out?
I thought about running a super aggressive compound on the rears with very little pressure to them, might feel like crap but would still like to try
RuskiWeldFab
  Clio 172, RS4 B7
Funny enough I had a similar idea. Currently have generic ferodo pads at back. But have a set of PBS wanna try out.
Front brakes are going for a full overhaul ;) big update coming soon. There is been some proper cooking in me kitchen haha
Twingo 1??
  Twingo 133 Cup,
Will be follow you guys with the brake upgrades. Although mine will be for a Twingo and used for rallying. It will be interesting to see how the 133's hold up as its a similar set up to the 172/182 same discs but uses laguna mk3 calipers.
BIFCAIDS
  340i M-Sport & 182
and almost lost a wheel on the very last lap. as I didn't have spigot rings for my OZ Sparco wheels (completely forgot i needed them) so one of the studs got lost. and i ruined on of the hubs in the process. oh well, my fault again.
I lost a wheel at Spa... that wasn't fun at 100 accelerating around Pouhon. I'm not going to lie, poo came out.
(Top photo was in the paddock of death, bottom is its replacement 3 weeks later)
After examining the hub, wheel, studs and spacer... findings pointed towards a generic JJC 16mm spacer. They don't sit 100% flush to the hub and we're talking less than a millimeter, still enough of an issue to undo 120nm on a couple of the nuts. Odd thing is, didn't feel anything through the wheel up until everything failed. So no more spacers and I've ditched the F1's for ET35 TD 1.2's.
RuskiWeldFab
  Clio 172, RS4 B7
thats crazy man! glad you are ok! super lucky you went straigh in to kitty litter. could have been rolling for quite some time!
1985michael182
That's gutting to watch when it's not your fault, I'm not sure what make my spacers are but I'm definitely going to check them now after watching that
I've come back for a decent reading session on here and you lot have all been busy on your cars this year and I've been busy working :(
I really do need to pull my finger out and fit some stuff to my car! its got 10% of the stuff this car has! IF that!
The car sounds great and that video with the camera's mounted in different locations is brilliant! I was fixated on the suspension and wheel movements and I'm sure this is exactly why you placed it there, so you could see just what alterations (if any) may work best!
great thread and ill be back for more to see how this progresses! top work
RuskiWeldFab
  Clio 172, RS4 B7
September 2018
There is a lot of talk about aero pros/cons etc.
But I wanted to try myself. Partly cos I am stubborn and extra 5kg won’t make a difference and partly cos I like making things. Used 4mm ally for brackets.
12mm marine ply
extra cooling ducts,
And lawn edging for an air dam.
Will test tommorow at Bedford. One thing for sure it looks cool and will be hard getting on/off trailer..
Extra weigh shaving
lower ducts aren’t connected yet. But will be routed directly to new calipers with 51mm hose
robzracing
September 2018
12mm marine ply
View attachment 1387612View attachment 1387613View attachment 1387614
Extra weigh shavingView attachment 1387615
View attachment 1387616View attachment 1387617View attachment 1387618View attachment 1387619View attachment 1387620View attachment 1387621View attachment 1387622lower ducts aren’t connected yet. But will be routed directly to new calipers with 51mm hose View attachment 1387623View attachment 1387624View attachment 1387625View attachment 1387626
Looks good Ilya. Just watch the rear doesn't get too light in high speed corners.
I'll be at Bedford tomorrow actually. Look for the Race prepared 350Z. The car will be there from the start but i won't be arriving until about 10am.
RuskiWeldFab
  Clio 172, RS4 B7
Splitter looks mega [emoji848][emoji1303]
And it works mega! A bit too much downforce! Rob was right about rear getting light in high speed corners lol. Did a short off-road course past the pit straight at Bedford yesterday. Mowing the lawn with that blade ha ha. After dialled in suspension a little softening the rears and stiffening fronts just a touch. Need more aero at rear 100%
RuskiWeldFab
  Clio 172, RS4 B7
Little vid from Bedford 25/09/18
I am happy, it’s faster around Bedford than my RS4 by a good 6sec. Not that I was timing or anything. [emoji13]
Camera is about 4inch from
The ground. Hard mounted to splitter. A little too low I think. Need to revise that.
