Induction kit?
Car  Clio MK2 ph3 1.6
Hello helpful people (hopefully) I'm looking for an induction kit for my 2004 (54) Clio MK2 ph3, but struggling too find one that fits because of the rectangular fitment into the block as all I can find is round ones, help please
What engine is it?
Assuming you mean mk2 phase 2? Phase 3 didn't come out till 06 did it? The one with the wierd boot lid?
Got some pics, am I looking for something that connects to the oval housing or the square
Bit of an update/research, found an old thread on here via Google of the kit too buy for my model, just don't know what one too buy. Photos and a video of noise results although I won't be driving it how he does
Any info on product appreciated, cheers
The changes in Ph on the Mk2 where body and interior related. They won't have changed the induction setup on the k4m so you are looking for any setup that claims to fit a Mk2 1.6 16v
You could even just measure the oval and buy a section of silicone hose a couple of jubilee clips and a generic air filter.
I looked into buying a bit of hose for the oval bit but it's 115mm so was quite expensive, see how cheap a kit I can get
Going too bump an update, took some stuff apart today and as well as having the main air inlet which Is 85mm there is another small air intake which I'm guessing too cool the oil as there was residue around it, how do I get around this if I bought a silicone hose too go straight onto the block
Which did you go for, think it would look silly with a small cone filter and and surely a catch can would be ratlling around all the time which would be equally annoying
Decided not too buy a kit and do it with silicone pipes now, and I can get a t piece too solve the other inlet issue . And I can do it all in blue piping which I would prefer
Conkered this today
Stripped out factory airbox
Installed breather for crank pressure thanks to @MonkeyKnifeFight for this solution
Then put the jigsaw together
Happy with noise and look results, no noticeable power difference but this Is just a project too clean up the engine bay.
Comments welcome
*little update*
After some advice given I fabricated a heat shield from some scrap metal for the induction kit, whilst I was at it I sprayed some other bits up and used some iron out too clean up underside of bonnet now looks like New, just want too spray battery casing yellow and I'm done
*Another update*
Finally got around too spraying battery cage yellow.
Also wanted too go with 1*2 look for the induction kit as it was also getting a lot of heat soak. Super happy 😁
