Rear beam removed, anyone know the part no for the clips that I've broken?
Car  182 FF
The six bolts that secure the two brackets that the rear beam attaches to put up a right fight but i got there in the end, the casualty in this battle were the clips that sit under the head of the bolts that you get at under the rear seat of the car. Does anyone know if i can replace the clips only, the bolts are fine and will clean up, unless they are stretch bolts? Can anyone help please?
Cheers Paul.
@italian job
77 03 002 732 rear axle bolt £6.56 x2
77 03 034 251 rear axle nut £2.15 x2
77 03 015 200 rear axle retaining bolt x6 £7.97 These are what you are after.
I suppose their only purpose is to stop the bolt turning so no harm holding it in place with mole grips, same end result. Cheers
