PMS ac delete/pump bracket removal
haimsey
Car  ph2 172
After a little help, having some confusion with removing the bracket that the a/c mounted to (might be being a bit thick). See attached picture for reference, three bolts out the front and it’s not shifting - can see two bolts on the left of the bracket, do these need to come out?
Also looking for some reference images for the mounting arrangement for the pms kit (pic of the version I have attached)
Cant remember off the top of my head when removing mine but wasn't overly complicated
Have you looked on the pure motorsport website at their guide as it is quite helpful
Does it look like the bolts hold it in, can you see a split on it where it would seperate if you removed the bolts on the side?
Looks like there’s two bolts that go in the side I f1 the Ac pump bracket. Ones a bit awkward due to the roller being in the way.
PMS website guide has been updated to show the new bracket design. I emailed to see if they had an old copy but they replied saying they saved over it
The new bracket design should still reference removing the ac bracket and maybe mention the number of bolts etc to remove to give you some idea
Yeah I had another look, must have had a moment of being a div, clearly says 5 bolts lol. Mustn’t have read it properly, I blame the poor lighting in the garage tbh....
