Ph2 Meg 225
				Stock calipers are the iron ones like on the S14 ?
You can upgrade to Ali calipers from a Z32 TT or Ali calipers with larger discs from a Skyline GTS-T.
Keeps it fairly original (still Nissan stuff) but there is a fair weight difference between the Iron and ali units.
They are cast iron, I have actually considered the z32 Calipers or even the 350z Brembos and r33 rear brake setup but it comes down to budget, z32 callipers would probably be the favourite.
you seem to know quite abit about s15s, did you used to own one or work on them? Would like to find a local specialist, slide motorsport any good?
Looks good - miss mine sometimes.
Did the exhaust come with it from Japan? My old Kakimoto system I imported has had a few owners now here in the UK.
Thanks! remember seeing your thread a couple of years ago, prices have increased a fair bit since.
Have you seen the prices of a clean aero spec r now like what you used to own?
The kakimoto came already fitted to the car, the only thing I would prefer is if the backbox sat straight rather than an angle like it is but apart from that it’s a nice system, not too loud and doesn’t drone.
Did you have a regu06r on yours?
