Racing Blue 182 Restoration.
Status
Not open for further replies.
Until you mention you were painting it, don't use it if you paint it.
I recommend ignore paint and just go enjoy it 😋 :ROFLMAO:
Estimated servicing cost.
£700-750.
Req.
Cambelt kit
Aux Belt kit
Dephaser pulley
Cam Seals
Crank bolt
4 Plugs
4 Injectors
2 Rear exhaust mounts
Oil Filter
Oil
Pollen filter
Air filter
Oxygen sensor
Exhaust centre mount
Lower torque mount
Thermostat gasket
All that to fit plus fit springs / climate panel / & sort out a brake pipe.
S
Parts beginning to arrive.
Spend up to £1415 now
EST final £2500/2600
Wait
j
£700-750.
Req.
Cambelt kit
Aux Belt kit
Dephaser pulley
Cam Seals
Crank bolt
4 Plugs
4 Injectors
Oil Filter
Oil
Pollen filter
Air filter
Oxygen sensor
Lower torque mount
Thermostat gasket
S
no water pump??
For the sake of £30 why wouldnt you just replace it?!😂
It's not as if you're scared of spending money Steve😂🤣
I did ask > reply came back not required > It was changed in November 19.
The only reason im doing belts again is because of the usual clownshoe fu*ups not done properly in Nov 19
- Patent part belts
- No dephaser
- Cheap aux belt > probably wrong size
- No aux belt tensioner
- Timings out
- Thermostat gasket is leaking
- Cam cover is leaking.
Bodgit & Scarper.
- Patent part belts
- No dephaser
- Timings out
Bodgit & Scarper.
reading that list, I’d definitely replace it for piece of mind.
Parts order Summary.
£577.
Labour est £400.
Final Mechanical work £1k.
( Extra parts was Cam seals / Water pump £95 + the aux kit from £77 RPD )
Thank god its discounted.
Sorry if I missed It but is this a non cup car?
You planning on putting stripes on it? I love the stripes on the RB.
Once you put the springs and spoiler on is it much different from cup pack?
Stripes and some trendlines and it would be perfect.
Had a final review of the parts today.
Cambelt kit
Aux Belt kit
Dephaser pulley
Cam seals
Cam seals - the other side
Crank bolt
4 Plugs
4 Injectors
Oil Filter
Oil
Pollen filter
Air filter
Oxygen sensor
Lower torque mount
Thermostat gasket
Inlet seal
Water pump
Skoda Splitter
Arch Liner
PMS Stub Axle spacers 10mm
Front Spacers 16mm
New rear bumper Lamp
Grams Springs.
Cup Spoiler ( used )
£1150
All in.
+ Labour to fit.
Already looks loads better from when you first bought it!!
Clean headlights are the key to making any car look so much better imo
Yeah
Going in for paint next weekend
Then will fit splitter / Spoiler & another full detail should be getting close then-
Then new windscreen glass - Love clear glass
Managed to find a Carbon splitter for it today as well !
£75 Sheckles.
I always wrongly assume RB to be unlacquered, I need a bit of a front end job on my flamer but I think a new bonnet is in order
Where its at
or
Where its at
or
I remember it when I picked up my arctic from yours in Bexley Heath, at the time I'd have taken it instead
I only sold WJ04GKU a couple of years ago, should never have done as I've wanted it back ever since. I think it's still alive though.
no mate. I always use phil
@DomP182
You sold your phase 1 on 66k for £1300!
Criminal!!
My girlfriend 'filed' all the service history, it never turned up! I remember I was going to trade it in with you but you weren't interested when I couldn't find the history. I was gutted about it I can tell you!
Status
