Call of Duty Modern Warfare
Ray Gin
  Tesla & Impreza
Changed my picture setting to FPS on monitor. Just out of curiosity. Noticed some ghosting so changed back to default. Now the ghosting is quite severe. Any thoughts guys? Preconditioned BenQ monitor, so not brand new.
d19wood
  Clio 172 T , Megane
If it was just the monitor you changed and not graphic card control panel. Try turning off all dynamic options in advanced control panel and make sure AMA option is turned on then try the highest refresh rate you can 120Hz? Whatever you can do to speed up the refresh rate and reduce the input lag the better I've found.
Been messing with my screen this week too with some good, some bad results
imprezaworks
  Mk5 Golf GTI :)
What settings to you have it one?
Ray Gin
  Tesla & Impreza
Sorry should have said, PS4
Default (gamer 1)
Ant1
Brembo! Brembo! Brembo!
This is what happens when you lose the gulag.....
Mouse meets screen.
ChrisR
Had a proper go today for first time in ages, tried to do the quick scope challenge to get that new sniper.
f**k that, managed 1/15 progress, found it impossible to get my snipes to register as quick scopes :(
imprezaworks
  Mk5 Golf GTI :)
Was In the gulag with tht hdr. I'm quite good sniping tbf. Off we go, boom dead. He slid across and quick scoped me before I knew what the hell was happening. Looked a bit suss as it looked to be a head shot.
Probably cross play (jokes)
d19wood
  Clio 172 T , Megane
I did it on HC using the MK2 carbine,
tac laser, slight of hand, ultra lite or extra ammo stock, stippled grip with choice of optic. You'll have it done in no time 👍
ChrisR
Didn’t try it with the carbine yet, only one I had success with that I tried was the kar98.
Im only a freebie warzoner, been playing Rumble to try and get this!
d19wood
  Clio 172 T , Megane
That will be a bit harder than HC but run tune up as 3rd perk and stopping power field upgrade for 1 or 2 shot kills and you'll be fine @ChrisR
N0ddie
  Tesla Model 3
So folks. Which perk do you guys run in perk slot 1? I run cold blooded but have been tempted to try EOD since C4 seems OP.
Aaron..
EOD in slot 1 but C4 will still take you out I think.
Had a few invites last night from Dazzachezza? Sorry mate, was halfway through Duo's with @16v_er both times. Finishing 2nd again due to my inability to finish games off/ poor decision making.
Ray Gin
  Tesla & Impreza
Just can’t play warzone without double time. Get around the map and inbetween buildings so much quicker
Jonnio
  Punto HGT Abarth
Decent one from Friday with @Moonshot and his mate. Could have gone so wrong early on as we weren't even bothering to play lol.
