NorthloopCup
And that’ll be the solution to the diff found
The main man is on itOffending item ready to go away for work View attachment 1510788
That was going to be the next step if I couldn’t get it how I liked but one of the issues was also my calipers. I was getting no brake then fully locking them up with just a tiny bit more travel on the pedal.I recently fitted the PMS pedal box in mine , pain in the ass to fit , but what a difference , not cheap but well worth the money , my grey one also has one , fitted by Mike,
Yeah I run servo, but I did on the old car too and it took a lot to lock the brakes.Do you run a servo on yours , when I first put the AP kit on mine it was either on or off , no feel in between , so I disconnected the servo and ran it like that ever since I rallied it , needed a good push to lock up , but plenty of feel before it did lock up
Yes but we have 2 sets. 1 is perfect and brakes are like hitting a brick wall and the other is on or offIs this the brembos? Thats what mine has been like, nothing for ages then on/off. Very hard to modulate..
hmm, Im going to give them a rebuild and see from there.Yes but we have 2 sets. 1 is perfect and brakes are like hitting a brick wall and the other is on or off
It was the ramp angles in the diff generating 90% of the issues mate.@Nathan Evans Ive just tried to remove the pistons out one, 1 piston moved easy which was brand new when I rebuilt them a while back, the other 3 which were original and showed no signs of wear are pretty stuck. All I have is a small electric pump which is maxing out, needs a proper air compressor. This is probably whats been causing the pedal problem.
The brakes?It was the ramp angles in the diff generating 90% of the issues mate.
Yes mate. Caliper pistons were sticking and he’s had issues with the master cylinder, but the ramp angles in the box for decel were utterly ridiculous.The brakes?
Glad you got to the bottom of things. But Im open diff and my pedal is s**t!Yes mate. Caliper pistons were sticking and he’s had issues with the master cylinder, but the ramp angles in the box for decel were utterly ridiculous.
All still on that standard motor too which credit to the mapper getting 212bhp out of it.Proper little thing that. When's your next rally? Should go well now!
25th July and 29th AugustWhen is the Epynt races? I’m pretty local, if they’re allowing spectators.
31st May which is bank holiday Monday. Even though it’s a circuit round it’s probably the biggest rally of the year as it’s 1st round of the British rally championshipWhen’s Oulton?
You’d be surprised how many are actually available for the clio, in France you have to have an airbox on the bodies. Not sure why but a foam filter isn’t allowedSurprised it's taken so long for someone to come up with an air box like that!
Mate if only you knew about the stress and rushing around before he even got out of his unitWell done today Nath, great result, and for Josh too.
Definitely taking it to the RWD boys - never seen so many Clios in the top 10 of the 2.0-litre class!
Mate if only you knew about the stress and rushing around before he even got out of his unit![]()
Well, yes and no lol. The main thing is, all areas of concern were identified and rectified mate. But there was a lot of head scratching going on in my garage on sunday morning before the culprit was found - and it wasn’t even the actual real culprit of the issue in the first placeSome last minute gearbox issues weren't there?
Cheers man, the lap without him in front was 6 seconds quicker, I was loosing so much momentum in the corner having to slow for him.The fact that Fiesta only pulled away slightly on the straights just shows how much you were nailing those chicanes! Good f**king driving
Hahahahah bless him, just goes to show money and skill are 2 different thingsCheers man, the lap without him in front was 6 seconds quicker, I was loosing so much momentum in the corner having to slow for him.
My brother caught him on a stage and put it in his rear quarter![]()
