I have this exact same thoughtGenuinely when i snapped that stud I was thinking how easy life would be in a boring modern diesel![]()
I bought a Clio... then another... then another... then anotherFor that exact reason I have both. Nice to be able to mess with the Clio and not care about deadlines.![]()
And then set about buying a megane... and anotherPls stop the suffering
Itll cost me more to go back to standard from this pointOr leaving the bloody thing standard would probably prevent such issues!
Don't be so stupid PaulinaOr leaving the bloody thing standard would probably prevent such issues!
Definitely gonna be getting snow tyres on those f1s. Clios are so light and have enough power to sit in a high gear so they go everywhere reallyI dont care what people say, clios are ace in the snow and ice
My old dCi never got stuck![]()
Probably 195s, I reckon theyd rub on 205sI bet they're ace on winters, would you got for a 205 width or 195?
We had a bit of freezing rain the other day, getting out on PS3 was a bit of a challenge
I'll help you change your mind
Dont do me like that Dan
To be fair, I had zero momentum having just made it up a proper step hill and turned inBusted.
Where are the African blokes?
Let me know about the blanks for the heater ventsStarted to give the inside a clean and got sidetracked by all the badly routed wiring inside. This has been down to dashcam installations, terrible alarm wiring and then the usb fitting I did when I first got the car.
Spent most of today rerouting all the dashcam wiring and making it much neater then also removed the usb as it snapped on the cap.
The wiring for the alarm LED is just something else. They bundled up these wires and just tucked them away..
View attachment 1523932View attachment 1523931View attachment 1523929
Found the connector within but theres way too much cable either side of this! Going to de-pin and shorten it. Managed to snap the connection to the LED so can also cut back and resolder this too.
Also swapped over the injectors with the brand new genuine set. Nice to have clean new clips! Managed to get fuel in my face when disconnecting the rail so watch out for that pressure
Removed the heater channel tubes that I'd originally cut back when fitting the xlow subframes. Going to 3D print some plugs and get them fitted so it's not just heating up the cup holder.
Tbh I dont know how well a set of blanks will work as the wall thickness towards the back is super thin. The original fixtures must absolutely piss air out of the sides! Barely even connected up and come out with a tiny tug.Plugs would be great if you can make them. I think Renault has proper caps for the Kangoo. I used Dei kevlar tape. View attachment 1523970
It always comes out with a tiny tug, just ask @Yorkshire PuddingTbh I dont know how well a set of blanks will work as the wall thickness towards the back is super thin. The original fixtures must absolutely piss air out of the sides! Barely even connected up and come out with a tiny tug.
Kinky bugger xIt always comes out with a tiny tug, just ask @Yorkshire Pudding![]()
Hi Louis,You need 8 of the cage nuts.
Thanks mate, much appreciated!These are the ones I've used when I fitted my new condenser and radiator
CAGE NUTS A2 STAINLESS STEEL SERVER RACK MOUNT CABINET PC CLIP NUTS M4 M5 M6 M8 | eBay
Find many great new & used options and get the best deals for CAGE NUTS A2 STAINLESS STEEL SERVER RACK MOUNT CABINET PC CLIP NUTS M4 M5 M6 M8 at the best online prices at eBay! Free delivery for many products.www.ebay.co.uk
Seemed to work well!
