Kangoo Compact (aka Racevan3)
Love it, proper mental little micro machine. Really hope it's at CSF (y)
For such a small chassis, how do you find it handles with that much power?
Cheers mate. It seems to just be like a meglio with a frock, wheelbase is 200mm shorter and 170mm shorter than 182.
Lsd pulls it about a little on camber on the roads which keeps you on your toes. It struggles with traction at higher torque levels compared to megane rs even though weight is similar. Overall, not bad have driven more lairy fwd. Feels pretty quick.
Credit where credit is due bud, it's a cracking build. Amazed that it's that much shorter than a 182!
Not surprised it feels quick with 350BHP behind it :LOL: if it's on track at CSF I'll be collaring you for some passenger laps
Would love to see the VXR driver face :ROFLMAO:
Great work as always!
Cheers mate ! Vxr driver just give up. I also made a 19 reg golf gtd go backwards fast. Was hilarious as he was trying to be clever and failed. Laughed at him:LOL:
Cheers mate! Its mad that its shorter than a 182. Pic of them back to back. Collar me for a passenger lap at CSF, be first shakedown so will see how it goes. Hopefully well:LOL:🤞
Updates
Had a bit of spare time this week on an evening as been off the gym. Supposed to be resting my arm up but yeah..
Went to Asda on Tuesday in it and heard the cars on track at Teesside so popped over. On way back was nice evening/sunset so got some pics down the sea front on way back.
Got talking to a local fella who turned out to be a massive petrolhead, so was there quite a while and tide started coming right up to the wheels..its prob rusting happily after all the salt air :LOL:
Got chance of some lift time Wed afternoon at a mates garage. Oil and filter change done, michelin ps5 fitted to the comps and geo done on the hunter.
Camber and toe was miles out initially and it was wondering a bit on the street. Not sure whats going on there but must have settled a bit since last geo.
Spiced up the front a little for Anglesey. Drives true again and straight on boost. Not tried cornering too much due to traffic, have chucked it into a few roundabouts and turns in nice, where it was a little understeery before. I was always a bit dissapointed with the understeer considering rs perfo hub setup but we will see how this goes.
Castor still a bit out but cant get nothing on that on current setup.
in theory its semi slicks and full tank of fuel and its good to go. Ill prob change rad for oem meg before we go as concerned the aftermarket is not up to the job. Easy enough job to do.
Thanks for reading!!
Updates
View attachment 1655694View attachment 1655695View attachment 1655696
Camber and toe was miles out initially and it was wondering a bit on the street. Not sure whats going on there but must have settled a bit since last geo.View attachment 1655693
Spiced up the front a little for Anglesey. Drives true again and straight on boost. Not tried cornering too much due to traffic, have chucked it into a few roundabouts and turns in nice, where it was a little understeery before. I was always a bit dissapointed with the understeer considering rs perfo hub setup but we will see how this goes. View attachment 1655692
- 2.00 is about right Jon, should be great on the track.
Updates.
More datalogging, still had a slight overboost situation up hills/max load. Ive knocked 1.5 turns of preload off the acutator to lower the base pressure and done extensive datalogging on the road late at night. 100% confident its bang on the money, 22psi tapering to 19psi under full load up hill and 11.7 afr tapering to low 11s up top.
Got a fine as forgot to pay the merseyflow on the way back from efi. Could have took a better pic for £22 :LOL:
I was running an evol dogbone and the bushes had fallen to bits on both sides and causing a knock in reverse. Bought a posh vibratechnics dogbone and fitted that.
Finished off my spa intake temp sensor. My friend alloy tig welded it for me. Pressure tested all good, sensor threads sealed with locktite 577. Fitted, works good.
Fitted the technomagnesio/A048 M/H compound semi slicks in prep for CSF. Looks mega like compomotive mo5.
Also changed rad for new oem renault so no chance of it getting hot. Its been road tested today/datalogged all good.
Done as much as i can so that will have to do!
Thanks for reading all.
Thanks all!
Didnt see the wags thread :LOL:
If the stars have aligned i should get more than 6 laps this year at CSF. Hopefully nothing will go wrong and itll be a good one.
CSF update.
Csf done and pretty successfull overall, the stars finally aligned. 600 miles on the trip, 3x tanks of fuel and 4x track sessions on the pm.
Sat ready to go with the Extra.
I was anticipating a 2 lap wonder and something to go wrong so had datalogger in initially for first few laps. Checked logs, coolant temps were very good 87deg, Iat great 5deg above ambient, no timing pull or noticeable overboost issues.
I thought id broke it with vibration on certain parts of the circuit but was due to the epic amounts of rubber on the circuit.
Full send after i got used to driving it. Its quite hard to pedal, suspension needs dialling in better and you have to feed the power in on corner exit as its pretty lairy. Can rotate the back end nice with trail braking on the tighter corners. Its planted at speed on the throttle and when cornering but its a bit twitchy on high speed braking 100mph + but controllable.
Finally works. Pizza on the evening to celebrate success.
Spotted on the way back on a55 iirc?
Back at van HQ safe and sound.
24mpg overall, not too bad. It was drinking it on track so assume it levelled out on steady return journey.
Give it a once over and all seems to be good. Have refitted the white mo's with the cup2s as more road friendly.
Both vans were epic mate. My lad thought they were mega, as did I.
Cheers mate! Was good to catch up.
Had mega fun in the Extra catching you up at the back end of the day. Back end looked lively on it!
That van is bonkers mate, proper rapid. My Mrs turned up at the end of the day so I asked her what the M3 sounded like and she said "I couldn't hear anything other than the van" 🤣
My tyres had turned to playdoh by then so it really wanted to get sideways.
The guy who did the briefing warned me at the start I'd be off the track if they caught me going sideways so I was keeping it in check the whole day 😅
Long time no update!
A couple of vids i forgot to add from CSF. The exhaust is loud as feck for a meg engine on driveby!
@MarkCup 's awesome footage.
Ive not really used it much since Anglesey sadly. I did take it out for a hoon one night and my mate confirmed it puts large flames out the exhaust at night after a long pull in 5th gear! also ridiculously low mpg 15-20 from memory:LOL:
Motivation has been low for car washing or detailing recently and not cleaned it since before Anglesey. Wheels were black with brake dust and rubber marks all over and loads of bugs all over the front. A good hour later and its back to clean.
Will see how weather fairs and might sorn it at the end of the month if it turns.
Its class this. Still can't believe i've not seen you around the Teesside area
Cheers mate! Not used it much recently if im honest. Mpg is fcuking horrendous on it low 20s all the time normal driving so hurts the wallet a bit, and ive been working away too so always in the blue clio. Had it out a couple of weeks ago for a blag about though and now its sorn for winter.
Need to start looking at ecumaster install soon.
Small boring update.
A bit of prep for winter layup.
Fired up and ran up to temp as need to drive onto small ramps to get the jack underneath. Fired up first time as if it had ran yesterday.
Jacked up and ph1 225 wheels fitted, ds1.11 front brake pads removed and stock brembo pads fitted. Discs coated in xcp rust block to stop excessive corrosion. Coilovers and other parts coated in xcp whilst up in the air for corrosion protection.
Looks gash but saves sitting outside on the cup2's.
Compomotives cleaned inside and out. Some savage fallout off the ds1.11 pads, a decent dose of BH autowheel removed 99% of it.
Bagged up and on the wheel rack in the garage until next spring.
@Brigsy - A bit late to the party, and kinda new here, but i've gone over this thread in detail, and am blown away, what a stunning project, and spot on as I would have done it (though might have chosen a Scenic as a basis and not a Kangoo). I really love the fact it looks totally stock, as though Renault have done it themselves, and the attention to detail which really looks mega.
Thanks mate. It all worked out quite nice for an unknown conversion. Only downside was cost!
Looking forward to better weather, will tax it and get it used again.
2024 update.
After coming off the road in October last year the Kangoo is taxed and back on the road.
Started straight up no hesitation today first crank. Jacked it up and changed wheels for the white compomotives. Whilst wheels were off checked everything over for mot, all looks OK.
I had coated all suspension and alloy underbonnet components in xcp rust block before winter hit so no changes really. Even give the discs a good coat of xcp to keep them right and there was only a slight bit of surface rust on them, so worth doing if your laying a car up outside to save the thick rust forming that takes ages to clean off.
I did however suspect the rear calipers were binding a little before i took it off the road as it hardly moved after CSF, so whilst rear wheels were off i give them a once over. The pistons were slightly tight winding back initially - worked piston in and out a couple of times with some red rubber grease to lube and they seem fine. Cleaned up pads, sliders etc whilst there and refitted.
Taxed and drove it to tesco for some fresh momentum 99 and a 30 mile trip to makro.
Dinky
Nothing to report really all good. Forgot how quick it is - squats and goes!
Small list of bits to do.
Oil & filter change - was done before Anglesey so not ages ago but needs doing.
Whistle from exhaust manifold area when cold - assume very minor blow which shuts up when engine is hot. Noticed this last year will do some investigation soon.
Mot expires in 2 days - get that done in next week or so.
This awesome little machine never fails to put a smile on my face when I see the pics in your updates. 👍
Updates.
Passed mot. Oil and filter changed for fresh 10/50 millers cfs nt+. Old stuff was still pretty clean as had only done Anglesey and road miles, around 1200 in total. Examined it and no chunks or any other shite so that will do me.
Ive had what sounds like an intermittent exhaust blow for a little while and nothing immediately obvious when looking. To do sone diagnosis - bought a smoke tester. Uses Johnsons pink label baby oil to make the smoke :ROFLMAO:
Its acutually a fantastic bit of kit. I stuck the inflatable bung in the tailpipe and smoked the exhaust out. Looks like a minor leak on the decat where it was welded up at the support bracket and the wastegate pin leaks as expected - they all do that. I think its one of the stainless gaskets causing an intermittent whistle noise from cold so will continue to use until it rears its head.
Smokin
Inlet/boost cct check.
Do you even vape bro
As above - fantastic bit of kit for turbo cars. Id have bought one years ago if id have realised how easy it is to leak find over high pressure test. Still - both tests have their place so will continue to do both where necessary especially on boost circuit - as any leak will cost you power.
Apart from that its business as usual. Feels rapid for what it is and due to swb/power you need to keep tight hold of the steering wheel on boost. The bangs on the upshift and downshifts are insane and the way it revs for a hybrid 20t turbo is mad - still makes solid power at 7400rpm where your average meg on stock cams with a hybrid is on its arse around 65-7000rpm.
This highlights the need for good brakes as the speedo goes round quite fast. Need to get another set of ferodo ds1.11 pads for the front as currently on stock brembo pads - they are nowhere near adequate on this. So they will be next purchase as ive fitted the set i was using in it to the yellow r26 for Croft in 2 weeks..
Also used it for an oil disposal trip - had around 75ltrs id accumulated over a short period.
It has its uses - albeit small loads:ROFLMAO:
There is a yellow Kangoo on Facebook that’s running a similar setup to this, looks epic and like this - proper sleeper.
Yep lad basically copied off mine, ill let him off as hes sound though, its a nice thing.
Its lacking decent suspension from memory so id imagine itll be interesting to drive! Mine was horrendous before i fitted the Ast's.
Updates.
Got a set of Ferodo Ds1.11 pads for the front so fitted them on Sunday morning.
Ten min pad change.
Whilst in the area i greased the lower swivels on the perfo hubs via the grease bolts. These are an essential mod for mk2 meg to keep the swivel bearings right, do it once a year and you wont have any issues, and steering always feels a bit better when done. I have found that the passenger one always suffers with grease washing out and a bit of shite comes out each time.
Grease nipple in action.
Grease flushed through.
Took it out today to bed the Ds1.11 pads into the discs. 70-30mph x3 and its breaking arrow straight and very sharp as expected, with a nice contact patch noticed on both discs.
Usual Ds1.11 brake dust after 3 applications of brakes.
Took it for a shot across the moors and now the wheels are totally black with brake dust.
Might book a trackday up for it soon.
Thanks for reading!!!!
Updates.
Ten min pad change.
I hate brake dust 😂.
I’m not sure if they do them for the Meg but I’ve got PFC z-rated pads on the M3. They are cracking performance wise but produce basically zero dust. They are worth running just for that alone
They do for the MK3 calipers, should do for the MK2 i'd imagine.
Updates.
Throttle body gasket was leaking on the Kangoo resulting in a screeching sound on idle and on boost, noticed it develop intermittently after Anglesey/CSF last year but it had started to get bad when used recently.
Performance was down and found the leak via smoke test.
Ive never been happy with my homemade throttle adaptor and have a lead on a cnc machined billet alloy one to replace it but need to wait a few weeks for it to arrive. Opted to fix it to make it useable in the meantime until new one comes.
Front off in 20 mins.
On inspection the bolts holding the adaptor to inlet had worked loose causing the issue. Dug out the gasket paper and made a new gasket.
Posh gasket paper instead of cornflakes box.
Refitted and smoke test to check for leaks, passed no problems. Started up and no more screeching.
Smokin.
Whilst i was in the area i replaced the pathetic single horn to a more manly dual horn that @Crayola kindly donated a while back.
Small van loud horn.
Rebuilt and ready for action.
Next step was to road test. A few quick pulls to check boost pressure and afr with Rstuner hooked up to datalog. All good, feels stronger in the mid range again.
Rstuner in action, great tool.
With it running good again, i loaded my track wheels in to take to my mates garage for new set of Ar1's.
Fresh rubber.
Earning its keep.
Good to have it sorted again. Might book a trackday for it after CSF.
Can't wait to see this thing at CSF again Jon
Was good to have a passenger ride in it. Even if there was about 45 people waiting (sorry lads, but f**k you🤣)
Glad you enjoyed the few laps mate. Was quite hard to pedal it round there suspension still needs a ton of work. Currently working out a plan for that.
That smoke machine is seeing loads of action. Great work again 👍
Cheers mate. Wish i had invested in it years ago, makes leak finding super easy!
Updates.
Kangoo not moved for a couple of weeks, had a few bits to pick up today so took it for a run out.
Anti Social parking as usual.
Work van nothing to see here.
Perfect vehicle for the task.
At max load capacity.
In other news my billet throttle adaptor should arrive this week. Im also looking at ordering harder 80nm springs for the Ast's to try out.
Been thinking about ecumaster black install soon as had it in stock for over a year! This would allow for boost by gear and a few nice bits.
