Renault Wind - Engine swap to F4Rt
  Renault 1.2 TCe D4Ft
Hello there,
After driving my Wind 1.2 TCe for a while now, I started to think about a possible engine swap.
The engine is starting to get old, so instead of a new 1.2, why not a bigger one...
Two options:
1.6 TCe or 2.0 TCe.
The Wind comes stock with a 1.6 non turbo, so fitting the 1.6 TCe shouldn't be really a problem, but the idea of fitting the F4Rt is more interesting!
I would like to know, first, if it would be possible in theory and how to do it.
What do I need?
I've heard that the loom of the 1.2 TCe, throttle body, ECU, turbo and all other sensors should fit like plug and play.
My questions:
Engine mounts?
Drive shafts?
Clutch?
ECU Map?
Fuel pump? (Walbro 255 enough?)
Exhaust? Can I keep the original one?
And gearbox... I would like to still use my stock gearbox "JH3 309" can I keep it?
I'm curious on what can be done... :)
Indeed, I popped a f4rt (304bhp in the end) in a 1.2gt twingo. If you search my threads you should find the build one. I tried to cover as much as possible in there, i modified the engine to accept a 5 speed also (y)
Hello Adey,
watched your videos lately and all I can say... insane results! Just amazing!
It's hard to find all the answers I need in your posts...
May I ask you some questions?
The engine mounts fits like plug and play?
Can I keep the drive shafts, or what can I do?
Your "basic tuning guide" says I can put a walbro 255 fuel pump, so that's not a big deal.
The exhaust? Can I keep the actual decat downpipe?
And gearbox... what modifications did you make, to keep the 5 speed? I have a JH3-309.
Thanks in advance!
Adey.
all the answers are there if you look, it depends on how you want to go about fitting it all tbh.
Engine mounts, no in a nut shell. You need the 172 cam cover modified to fit and the upper mount on the f4rt engine. Then if you use the 5 speed box mounted on it you can use the 5 speed gearbox mount, dogbone then needs a tweak to line it up from memory.
Drive shafts were covered extensively as I went through a few different setups. On the wind i think you have the RS133 suspension setup? if so I used them shafts with the 5 speed.
Basic tuning guide was written for the 1.2 GT turbo engine.
You will need the f4rt downpipe, I used a decat downpipe on mine.
Gearbox, Again it is covered, you need to use a 172 flywheel and an Rs133 clutch setup with the 5 speed box ( I used a Jr5113 gearbox, not sure if its the same fitment as the one you have) you will need to drill the block and fit a 172 sump to fit the 5 speed though.
try here
yes its loads of reading, 77 pages, but I don't think there is much in there that isn't covered. (y)
try here
Thank you very much, Adey. :)
try here
So, after reading everything until page 48, many questions I had, are now answered!
At least now I've got an idea, on how the whole process works.
My first goal, would be to just put the engine inside the bay and make it run, like the first start you uploaded.
I only need some little more precise infos...
I will need a Clio 172 sump and cam cover. If I use the 5 speed box, the engine will hold with stock GT mounts, correct?
To accept the 5 speed box, what modifications exactly do I need to make on the F4R?
Clutch: Clio 172 flywheel and RS133 clutch (With the 5 speed box).
The 5 speed box, which one should I use? TCe or DCi? My Wind has the JH3-309.
No way, that I can keep the GT Turbo? Even if I would like to stay under 150hp first?
What if I decide to switch to the 6 speed box of the F4R, would it be possible?
(Like easier way, but more expensive).
Ohh okay, I found the pictures of the block modifications.
Did you use exactly the F4R784 170hp?
Could I do the same as you with a F4R800?
Adey.
No you will need the complete 172 upper engine mount, the gearbox mount that matches the gearbox you use (if 5 speed, you can use a modified 172 dog bone mount)
Drill the block and add studs
I used a DCI box, i cant comment any more than that.
No the GT turbocharger will not fit the manifold of the f4rt.
yes you can fit a 6 speed, if you use a meg box you will need to modify the subframe and chassis rail, the 6 speed sump is bigger. you may then need to modify your driveshafts. you can use the 197 6 speed box with RS133 shafts. but the box is weaker.
Amazing, thank you! :)
After that reply, I can start looking for a F4R engine.
As long as I begin, I will start uploading pictures here.
  Renault Clio Sport
How it is going? My girlfriend also has Wind 1.2 tce, we have been having an idea for about year to swap engine with something better.
Hey there,
I'm having troubles on finding a F4Rt... :(
Here in Germany, I found one in "good" condition for 13k €! That's a rip-off in my opinion...
Project never abandoned, I will begin to post here as soon as I find a F4Rt774.
Fun fact: Can also work with a F4Rt770, same principle, but then it's just a 2.0L non turbo.
Grandpa Joe
Pallet shipping from the UK to you is an option. I've sent and engine to Germany before and it wasn't too expensive from memory. You just need to find a good engine and someone willing to strap it safely to a pallet.
Objective 1: Finding the engine. ✅
It's been quite a while since I last posted here.
The most challenging part was finding the right engine, but in the end... TADA! Here we are!
Things are starting to get real, I found this engine and the seller claims it's an "F4R 774," but I can't quite figure out if that's really the case, since the block is labeled "F4K."
Hope someone here can help, maybe I missed the plate with the engine model.
Brigsy
  T.Turbo
Dont worry about the f4k, my megane blocks also have it on. The actual code is on the front but usually almost unreadable due to rust.
Objective 2: Preparing everything. 🔴
So many questions, so fewer answers...
I want to document here as much as I can, and I'm sorry if it's too much,
but I would also like to show all my worries and how I eventually solved them.
There are many things that need to be cleared, I'll pin all the points:
  • Drilling the block
  • Driveshafts
  • Spark plugs and coil pack
  • Sensors
  • Intercooler
  • AC Compressor
Drilling the block)
I still didn't understand what's meant with drilling the block, so I went to a trusted local garage of mine and asked about this.
He said that some cars don't mount all bolts to hold the gearbox on the engine. If a bolt is missing, it's not that big deal.
Is that so? If no, how could I drill the block? (Never done this before).
Driveshafts)
As Adey told me, he used on his Twingo the RS133 shafts.
Twingo 2 GT and Wind 1.2 TCe have different shafts, but Twingo RS and Wind 1.6 use the same!
The question is, can I just swap the driveshafts from 1.2 to 1.6 and I'm done?
Spark plugs and coil pack)
After inspecting the new engine, I saw that it came with spark plugs and different coil packs than mine.
Like every spark plug has its own coil pack.
But watching Adey's build, he has the same coil pack as a normal Twingo II.
Explanation?
Sensors)
If I put both engines (D4Ft & F4Rt) side by side, do all sensors with all the loom fit?
In the documentation of Adey, I've read something like he had to make some wires longer than they actually are.
Making some wires longer is not that big deal, but the sensors; all plug and play?
Intercooler)
I know that's nuts, but since I want to test the build with a map with something around 130 hp, can I keep the original intercooler for now?
Custom pipework, of course, but I feel I don't want to spend much on something that might not work for now. Bigger/upgraded intercooler can wait, what do you think?
AC Compressor)
Also here, I am pretty sure Adey didn't care about AC, but is it possible to keep?
Twingo II and Megane II RS compressor have the same mounting position, but the pipework is different.
Can I put Twingo II compressor on the F4Rt?
For now these are my biggest worries, as long as these questions are somehow solved, I can keep the development.
I'll buy Adey's same gearbox, I feel like I want to do as much as he did, since his was a success!
