Grandpa Joe
		The reason people use 6000mhz with the 7xxx is to run the memory controller at a 1:1 ratio but you'll have to do a big of manual tweaking.Just a question, when you go on the AMD's website and go onto the Processors, then onto the 9000 Series, there's 4 currently listed I'm aware there's the X3D version coming out soon, but when you go onto the other Series like the 7000 , 5000 Series for eg theres way more varients on each series than the new 9000 series, does this mean there's more and more varients on the 9000 series coming out or is that it?
Also when you go on the Max Memory Speed bit on the AMD website there's 3600 and 5600 listed, but i know people on YouTube been putting on 6000 ram on. Can someone explain to me what's goin on, I'm confused. This is for the 9600x and the 9700x
The 9 series X3D haven't been launched yet but will be in the coming months, no confirmation on dates and models yet.
A reason why the older series have more models is because certain chips might only have 6 good cores instead of 8. They might only run at 4.3ghz instead of 4.6ghz for example. So they are released later on to slot in between other processors.
E.g the 5800X3D was the only X3D CPU for ages. Then eventually AMD released the 5600X3D and 5700X3D which could all be the same CPU on the production line but binned differently.
