Should a rebuilt F4R engine (RS200) eating oil after run-in?
Tony_HH
  Clio RS200 FF
I recently had a donor engine fitted. After installation, I completed a careful 600-mile run-in, keeping the revs under 3k. Following that, I drove another 1200 miles under normal conditions (never reach 6k revs)
Since then, the engine has consumed over 1 liter of oil within that 1200 miles. I topped it up just last week, and after only 350 miles, the oil level has already dropped by 2 out of 6 bars on the digital oil sensor.
Is it normal for a rebuilt F4R engine to burn this much oil, even after a proper run-in period? (Been to the garage, mechanic told me it is normal for the parts to eat some oil)
RSRowe
  Megane 250 Cup
You need to keep how you're measuring the level consistent (i.e. using the dipstick)
All engines use oil but I would say 1 litre per 1200 is alot for an F4R though.
Fill it up to the top marker on the dipstick and keep your eye on it.
Tony_HH
  Clio RS200 FF
Yes, I just checked the oil level using the dip stick, oil level definitely dropped
With regards to my previous post regarding oil discovered on the gearbox surface, filled 1.5L before heading to the garage last week, thermostat housing gasket was replaced, done 240 miles after that and oil is gone again
Louis
I Love Ed Sheeran
Was good talking to you the other day mate.
You need to find out what work was completed to the engine for it to warrant 'running in'. I feel they've just dropped an unknown engine without checking it over. I won't share the renault 'specialist' who has done this work.
R3k1355
Do you know if you're burning the oil or leaking it out? Have you pulled the spark plugs to check for fouling?
Maybe have a mate follow behind, if you're puffing out blue smoke on acceleration or deceleration, you know the engine's got internal problems.
Louis
I Love Ed Sheeran
I asked these questions.
Apparently it had no oil leaking down onto the undertray but also no visible blue smoke. No smell.
You'd expect 1.5litres to be pretty noticeable on a 'freshly built' engine.
For reference, my F4R on 168,000miles burnt around 1litre every 10k.
Tony_HH
  Clio RS200 FF
No blue smoke, no burning smell from the engine.
Tony_HH
  Clio RS200 FF
No sign of leakage or blue smoke, engine and undertray are all dry.
Tony_HH
  Clio RS200 FF
Been asking for mileage and condition of the donor engine, nothing came back
Sheilas’ Wheels
  Whichever has fuel
My 182’d van was burning oil at a rate of 1L per 1500 miles and that’s excessive.
Back of the van had loads of little black flecks over it. Yours got the same?? How sooty is the tailpipe?
Personally I’d be contacting the person/s you paid £3,800 to and put the ball in their court. But my spidey senses tell me they’ll fob you off.
Tony_HH
  Clio RS200 FF
Is that the black flecks as mentioned?
Sheilas’ Wheels
  Whichever has fuel
Wipe the back of the car down with some QD and a cloth.
Get it up to temp and do a few laps of the local dual carriageways, make sure you hit the limiter a few times. At least 30 mins of spirited driving.
When you get home, wipe a clean cloth along the back window (don’t want to damage the paint!) and I bet it will be covered in black dots.
But your exhaust looks very similar to my van.
Doesn’t look good. 😢
Tony_HH
  Clio RS200 FF
Oil comsumption is far too high If its been rebuilt, especially if standard pistons. Needs a leakoff test doing to confirm, but id assume ring/bore issues.
I will keep an eye on the consumption and arrange the test to be done asap
R3k1355
So I can assume there is a leak inside the engine / piston rings?
Could be the block needed boring and they didn't bother/bother to check and rebuilt it anyway. Maybe they thought they'd get away with just a quick hone.
Maybe they didn't even bother with that and re-assembled the thing.
Does the itemised bill mention machine work?
Tony_HH
  Clio RS200 FF
Yes, it mentioned machine work
Flob
Fully agree with all of the above - thats excessive oil use, the Renault service manual will likely give a figure for acceptable oil use which you can show to them.
If you think you're unlikely to get your money back I would personally take it to another (good) garage, get them to perform a leak down test/diagnostics, pay for a written condition report and then head to the small claims court.
Adamm.
If you speak to them and explain I think they will be willing to help my only concern is the incompetence in the first place that lead to the current situation. End of the day though with the money you already spent you either need some back and go elsewhere or get them to rectify it. If you can go with the first option I would tbh.
Tony_HH
  Clio RS200 FF
I have explained and bought the car to them last week, only potential oil leak was from the thermostat housing, gasket was replaced and no other signs of leakage. I am told the car is fine, just need to keep an eye on the oil consumption
Matt Cup
  Leon Cupra
You have done though and it’s by all accounts it’s excessive isn’t it? So surely they need to dig into it a bit further.
Filters
Wales - South
I don't understand how, from the itemised bill - that it's missing an oil pump, water pump and more that you'd expect to be on there, nor does it add up that it's £1620 more than a rebuilt lump from Engine Dynamics.
If it's chugging 1L of oil post rebuild in just 1200 miles, I'd be going back and insisting they fund a proper rebuild elsewhere.
No freshly built engine should be using that much oil. Ever.
For what you paid, I'd be kicking off.
