The Dog Kennel
DaveDreads
Probably, there's no helping that lad when he gets obsessed with something, that's why he sells them when they're done, it's about the build for him.
DaveDreads
I wasn't going to update this until there was more progress, but I realised it's probably a good place to try and source some parts before I start buying them off internet randoms.
The Clio went to the garage a couple of weeks ago partly to fill up a space in the yard, but mostly so it gets started and built so I've got a couple of months of testing before CSF next year.
The replacement engine has had a new cam belt, dephaser, water pump, crank pulley and a few other bits that went in one ear and out the other, the sump came off and the bottom end was inspected for wear which it didn't have, cylinders were checked with a bore scope and found to be mint, with the breather plate off the cam I can see also looks mint with no visible wear, the inlets have also been ported, not sure it's that's factory or aftermarket but it was a pleasant surprise.
The car was put through a mock MOT to see what it needed before it's pulled apart, nearside driveshaft is knocking, rear light clusters have lost their chrome so the indicators are hard to see, but the big one is engine loom, I've had so many electrical gremlins it's probably best just to replace it with a load of new relays and O2 sensors, we also think theres a problem with the throttle body / pedal, there's a delay like it's stalled when you blip the throttle, but that could also be loom / TPS related.
Parts needed :
Engine loom @Speedo Gonzales
Nearside driveshaft (or a pair depending on the seller)
Ph2 rear lights clusters
I'm sure Ryan will be along at some point to remind me off all the other parts I left out.
There are other parts I want but they're not essential to getting it running again, so they can wait for a bit.
DaveDreads
Nice! I've got them bits..
Driveshafts please
Where'd the engine come from Dave? I remember you were fishing for one a while back, surely nobody on here cane good? 🤣
Kiv in Bristol, I was going to message him for the other parts but I thought I'd try in here first.
I've got rear lights and engine loom
I was gonna dig it out tonight after work and get it boxed Dave
You're a good bloke, I didn't tag you to hurry you along or anything, it was so I didn't end up getting offered a load of looms I can't buy because you're already sorting it.
MatthewR
View attachment 1771246View attachment 1771247
Parts needed :
With the last bit are you wanting to get it up and running and then modify or are they some more 'nice to haves' but aren't essential.
I always found with my car's the nice to haves never ended up getting done 😂
DaveDreads
Yeah the 'would be nice' bits are stuff like rear arb, PMS shifter, bucket seats, harnesses, also need a new headliner, but none of those bits are essential for getting it back on the road, so at the moment I'm only spending money on 'definitely need', once it's running with an MOT I'll start buying the fun bits.
MatthewR
Sounds like a good plan, they are also bits that are more exciting so will get done.. I was thinking more like new side repeaters etc 😂
DaveDreads
Took some parts over the garage today.
In those bin bags are it's original wheels with Rainsports, it's currently on track tyres covered in marble pickup, even moving it around at 20mph risks throwing you in a ditch on a wet day.
And a very heavy dead midget.
Turned out to be driveshafts, needed a replacement for the nearside as it's knocking.
Rear lights have lost their chrome
New ones are secondhand but alot better than mine, before
After
Some Welsh bloke whose username is now unspellable left these in my boot which was nice, whether I can hear them over the engine and exhaust is yet to be seen.
Over in the corner looking sorry for itself is old unfaithful, massively down on compression, misfiring, coughing and spluttering with random cutting out.
Turns out one of it's main problems was an injector sticking open and flooding the engine, explains why it stank of fuel after it cut out and struggled to start back up.
It had another issue where it would just shut off at any speed, engine off with all electrics dead, that turned out to be a nearly dead battery and a slowly dying alternator that randomly went on strike, both now swapped for new.
The new engine's made itself at home.
I'll do some proper photos once it's finished.
DaveDreads
Little update, been sourcing parts for a couple of weeks so popped over the garage to do a few bits.
New tailgate struts as it kept cracking everyone in the head when open.
I've had the same air filter for 15 years, even though it's been washed re-oiled many times it's probably time for a new one.
Same with the oil breather although that's never been cleaned.
Love a free sticker!
This was heavier than expected, but definitely lighter than standard seats, it's going to feel odd sitting in a decent position instead of feeling like I'm sat on the roof.
I was going to do more but got told not to fit the injectors because I'm a caveman that doesn't know what he's doing, which is true.
I also have a Whiteline arb to go on the back but didn't fancy lying on the cold workshop floor covered in shite, so I'll tackle that another day when I've more space around the car.
DaveDreads
Headlining's out, most of the old glue came off with the lining so minimal prep work required to glue new stuff on, not that I did any of it.
So far I've fitted an air filter, a breather filter and some seat sliders, speaking of which, these were an arse to fit.
It already had sliders but the bar wouldn't fit so had to fit the omp kit, the slider holes didn't line up so I had to machine those out, bent the slider bar fitting it so that's on the piss, but it just needs to work not look pretty.
No idea if the holes will line up with the car, I have an omp base but only one side lines up, the other holes are miles off so new holes will have to be drilled.
Should be fitting the seat tomorrow if all goes well, announcement at 4pm.
DaveDreads
Headlining done with suade
Took most of the afternoon to do it right, potato phone decided to f*ck the photo up but you get the idea.
This as as far as we got today, new passenger seat that isn't covered in shite and seat base mocked up with threaded rivet nuts in the factory seat holes, just need to make up some spacers to get it level, then it needs to be drilled for the seat.
