Cookson
  Mk1 Audi TT 3.2 V6
I press this
MLB
I've tried the Rain X one but wasn't that impressed, keeping your windows really clean and then just use the demister is the only option that kind of works if you have no aircon.
MLB
I believe they all work based on lowering surface tension, by putting the fairy liquid on you lower the surface tension of the water condensating on the windscreen.
So instead of having droplets of water on the windscreen making it opaque the water spreads out and creates a 'clear' layer.
riz
  Jaguar XFR
The autoglanz one is good.
I also used the Koch chemie one
Not a Diesel!!!
  LY Meg Cup-S + MX5
That Koch FSE looks intresting. Detailing spay so can target areas rather than wash whole car. And pretty cheap too.
MatthewR
White leather..
My wife was a r****d and got a Tesla with white leather and now my jeans have transferred onto them 🙄
I've heard baby wipes are the best thing but want to know what options are available if I need to step it up!
Polynesian
  Alpina B3, 172, 325i
Claybar question.
I’m trying to do a decent clean on the MX5 and the Clio. First time claying either car.
Is this looking ok? I’ve used meguiars shampoo and a meguiars spray that came with the clay- when I clay a panel, keeping the clay lubricated, it looks like there’s some kind of contamination left behind. Just want to know if this is normal or if there’s an issue! (Paint is Mazda stormy blue, not the Clio, yet).
Yep, there are masses of scratches, hence claying and then aiming to polish. Thanks.
Turd Pocket
  Cumpact
View attachment 1775073View attachment 1775074View attachment 1775075Claybar question.
Looks a little bit like the clay has left some residue behind as its passed. Might not have had enough lube to keep it sliding about. Sometimes some of the clay 'rubs off' onto the paint. Nothing to worry about, give it a wipe with a cloth and see if it comes off. Might need to give it a rub (ooooeeeeerrr)
Polynesian
Thanks Nostrils, that worked and all good. I used some farecla G3 and it doesn’t look to have reduced the scratches at all. Any tips people? Before I let loose on the precious concours Clio.
Polynesian
SPTA rotary, 4 dots on a foam pad. Probably 4 passes. I’m new to this so sooner be careful than completely messing up. Thanks!
Crybert
  Cup 172
Rotary is brave for a beginner. You’re likely being too gentle with it but also the risk of cutting through the clear is high with a rotary. If you can get access to a DA try that. Much safer compared to rotary. 4 passes isn’t enough for that marring
What pad are you using?
Polynesian
Thanks for the advice. It’s the foam pad that came with the spta. It’s a cordless one and I’m using it on a low speed.
Crybert
  Cup 172
What’s the best way to remove scratches from gloss black trim?
Micro polisher. I use the cordless batoca one, it’s decent enough.
Gloss black trim is a f**king pest though, just look at it and there’s scratches on it.
Although the angle of where those scratches are you may need an even smaller polisher. A dremel with the correct attachment may be the best way?
KitsonRis
Anyone used one of these things to clean the underside of their car
Needs to have bigger wheels and not the caster wheels I’ve seen to cope with my gravel drive. And would need to work out if it will fit into my pressure washer, although I’d like to upgrade it this year.
NorthloopCup
I haven’t used this setup personally, but I just use the Karcher patio cleaner attachment turned upside down. I mix up BH autofoam in the bottle for the patio cleaner (karcher pw), as it has rust inhibitors in BH AF and send it under. I find it works really well tbh.
Matt Cup
  Iceberg 172 Cup
I asked about this a couple of months back and got something very similar, haven’t used it yet though.
This is the one I have. It’s a bit more low profile than the one you linked.
Pep
Living Dangerously
  M2,XJS,S1000RR
Gave my car a wash today and realised it’s pretty hanging and covered in tar etc, is below the correct order of works?
wash
ironx
rinse
tar remover
rinse
clay
rewash
will polish it a different day as that will be enough for my attention span!
  • Like
Reactions: MLB
