F31 330D xDrive
Another member to bimmersport.net.
I moved the 8V S3 on, it did many things really well, but just left me cold and I didn’t even get the smallest pang of regret as it drove away, so I guess that means it was the right decision! Plus I had convinced myself I need an estate as I have a 7 week old now, and I must admit I’m loving the amount of crap you can chuck in the boot.
I was set on a 330D, then a 335D, then in the end all I cared about was the correct spec as there’s not much between them.
Nearly compromised and went for a nice 335D in Bristol but just had that nagging doubt I would regret getting a poor spec’d car, like I did on my S3. Couple of days this popped up and within 3 days I was setting off 250 miles to collect…
F31 330D M-sport XDrive
-90k miles
-FSH
-Adaptive LED headlights with high beam split, adaptive m suspension, Pro Navigation, Harmon Kardon, reverse camera & 360 wing mirror cameras, heated electronic memory seats, heated steering wheel, blind spot/crash detection/lane assist, assisted cruise control.
And best of all - No stuck on aliexpress splitters, diffusers, skirts, not even a grille!
First up on every car I own…
Quick clean and it’s no longer shiny and full of someone else’s grime. Not perfect but better.
Dicky Belly
  Whichever has fuel
Lovely!
I find the spec on these is what makes me keep them long term. I’ve had so many BM’s where they’ve been poverty spec and I just don’t gel with them..
great purchase. 👌🏽
Klumpy Dumpy
It's hard to find an F31 335d with good spec
I must have spent 6 months looking for one and just gave up in the end. They were either nearly 20k or had been crashed into Temu headquarters and sold by someone with the surname Hussain or Pzgycholkyifhzagulashini
Flat Eric
Sing Hosanna!!
  F31 35d, Skoda Yeti
Should've upped your budget then lad 👀
Mine is a good spec 🤪
npt
  BMW 320d- 172 cup
They are a decent car, I would advise getting it undersealed including inside the front wings, they start to get crusty underneath at that mileage
Flat Eric
Sing Hosanna!!
  F31 35d, Skoda Yeti
Nice car. Best choice in colour too!
When you getting it mapped to ensure you keep the volvos at bay?
Willo40
  M135i
Really like that, i love that i only commute 10 mins to work, but when i see these i wish it was longer so i could justify buying a 330/335d, be interesting to see how you find it pace wise compared to the S3, spec is really good, i am sure you won't regret buying it.
First up was sorting out CarPlay. I’d seen on the sale ad that it had the NBT display so knew it would be somewhat simple to update and activate.
Defined Coding updated the firmware from NBT Evo H to Y, then a £30 code and you have OEM CarPlay! If anyone is Sussex/Surrey way then I’d definitely recommend them.
I’m obviously researching remaps at the moment but there’s a few maintenance bits I want to do first. xHP seems to be the one for the gearbox?
To start I’m looking at the ZF gearbox service kit and also the fluid in both diffs.
Has anyone done the same and know if there’s alternatives to the BMW Hypoid G1 & G2, or shall I just suck it up and stick with OEM?
GrahamS
Nice work! that's very highly specced which is superb.
You can do the alpina flash on the gearbox for free as far as I know using esys.
I'm near Sevenoaks in Kent. If you're this way I can quickly enable the following in 10-15 mins. I'm thinking of starting to offer limited coding packages so can do this stuff for free to gain the experience.
In addition, as you have KAFAS2 I believe you can enable HBA to come on automatically without pressing the stalk.
Thank you for the offer mate, I’ll definitely take you up on that, haven’t really delved into coding options yet! Want to spend a day doing gearbox/diffs/transfer case oil change then get a bit more power/gearbox flash.
Really loving the car to be fair, I’d like to lose the runflats but they have too much tread to just throw away. Feels so planted in sport mode, handles a lot better than my S3 did.
Also picked these up on eBay, no longer available new for the xdrive apparently but these were never fit. Just need the matching boot liner now!
£120 for Febi f&r diff/transfer box oil, or £225 for BMW…
Any experiences with Febi stuff? Or just go oem for the extra £100.
Klumpy Dumpy
How much would you like changing the diff on your back on the drive if it s***s itself?
ITs a different car but I use Castrol Syntrax LL in the diff on my E60 535d (I also added some silicone tube once to make things extra nice. Don't do this part)
GiT
  Shit little Yaris...
Amazingly clean shoelaces, whilst the soles are destroyed! Kudos.
Good point. For £100 odd I’m just going to get the oem bits from BMW, it’s not like I’m going to do it more than once so may as well just spend a bit more for peace of mind.
Is anyone clued up on the brake options for these? Autodoc is suggesting 340/370 x 30 discs, whereas looking on realoem I would have said 330 x 24 discs? Measuring the thickness suggests the smaller but I don’t know if there’s any interchangeability.
Can’t get to the FILs unit for a while so can’t just take the wheels off and measure…
I wash the laces to eke out a few more months wear!
I believe those are called poverty brakes👀🤣
Your taunts had me looking on eBay, £5-700 for a set of the uprated callipers, more for refurbished, but until I move jobs I just won’t be using it enough to justify that. Better spent on a bit of freshen up and then gearbox & engine map time!
Planning trips to France and Lake District next year, so will put some decent miles on then.
Good for parts so now I need to familiarise myself with the ZF gearbox procedure, lots of videos on YouTube so should be fine. Hoping to do it all on a Saturday after Christmas.
Had a play with BimmerCode/BimmerLink, last DPF regen was 40km ago and it has 6g soot, 28g ash remaining which from googling seems to be alright?
Also found this, don’t know if it’s good/bad, or of any relevance, will check once the oils changed.
Remembered I had these funky cameras so tried them out for the first time, pretty pointless to be honest 😂 a little aged/faded so maybe if they were clearer I’d trust them, maybe one day I’ll clean out the lenses…
Ian_R
Clutch Packs are good (y) The car i initially rejected from a dealer, turned out clutch A was -500 (Ie. Fucked :ROFLMAO:)Google to ZF official Manual and will give you step by step/or the official Video on Youtube Does the same.
MLB
What's the average mileage for regens?
Soot gets burnt off, the ash stays behind, I believe anything under 50g is good and I think I read somewhere that generally DPFs have a max capacity of around 100g of ash.
What did you use to clean the steering wheel BTW? Was that just cleaning or repainting as well?
365km. Says remaining distance of the DPF is around 87k miles so little over halfway through it’s useable life apparently.
I only used furniture clinic leather cleaner and conditioner, gliptone is another decent one too.
  • Like
Reactions: MLB
MLB
That sounds like decent long distances between regens, similar to our X5. Would be interesting to see a readout of cars that do a lot of short trips with a cold engine.
I'll have to have a look at them, ours came up OK after using gyeon leather cleaner, but haven't conditioned the leather and it's gone shiny again quite quickly.
Front & rear diff, transfer case, and gearbox oils all changed. Not sure if I’ll get an invite back based on the mess…oops.
Question for the gurus - when changing the gearbox oil, I could only get about 3 litres back in, went through the procedure (up to temp, 2k rev, through the gears) refill between 30-50°C, then got another 500 ml on the second fill.
Took it for a drive, monitored gearbox oil temp and by the time I got 15/20 miles home engine temp was 100°C, gearbox 83°C.
It felt a lot better, much quicker, smoother. Wasn’t overly impressed with the ZF8 coming from DCT & DSG but its mix more comparable now.
I have a nagging doubt that it should have taken more oil? Is it worth driving for a bit then getting it up again and topping it up, or would that overfill it?
-Jamie-
You should flash the Alpina software onto the box, I was extremely impressed with it the first time I drove it, it's so much smoother than the DCT was in the F80 and isn't that much slower really in sport for shifting
Flat Eric
Sing Hosanna!!
  F31 35d, Skoda Yeti
How did you go about doing it? I want to do it on mine.
Ah just typed this out and realised you have an actual alpina 🤣
Went out to clean it but given it’s about 2°C, I thought better of it.
Checked the filters and air looks good, in keeping with a service 4k ago which is reassuring. I’ll probably change the oil & filter in the summer before a few longer road trips. Likely change up to 5W40 LL04 as well, seems to be the done thing as these get higher mileage.
Cabin filter looked past it so replaced with a carbon Mann filter. Probably all marketing bullshit, but having been told little more than a canister of activated charcoal will save you from novichok, it must do something, right?
Contacted BW Chiptune about remapping, was hoping he could do it today as the other half and little one are out for the day, but he’s been closed over New Years. Can’t get up there for a couple of weeks at least now which is a pain!
Had a little time whilst the little one was napping over the last couple days and had complete my assigned gardening jobs…
Found this whilst tidying the loft, left over from my Z4 I think? But anyway, I’m an old man and don’t like road noise, and hopefully it’ll help the audio quality.
Factory sound deadening seems a little light
Not sure if the foam will do anything but worth a try surely? Don’t want to cause with the door card fitting so barely put any on. Need to do more research and can always whip it back off to add more. All 4 are finally done now, driving to Wales in a couple weeks so hopefully I’ll notice it then.
I’m still on a spending embargo whilst the other half is on maternity, but whilst driving the other day I developed a sudden, massive dislike for the brushed aluminium interior trims. Found a used set for a decent price, not sure what colour they are, they looked darker in the photos which I preferred, may bite the bullet and get piano black eventually, but good enough for now.
Im hoping it’s a subtle enough change she won’t even notice…
