Pouches for keyless entry/start
Andy_con
Car  clio 182
The wife has just purchased a new car and its got keyless entry/starting, she picks it up Friday.
Loads of cars are being nicked at the moment that are keyless.
There are millions of these pouches to stop the signal being transmitted, but im unsure which are good and which are bad.
Any tried and tested ones?
If a new car many now have motion sensors in the key so if left on the side or a hook etc stops transmitting, check that first making the need for a bag or box void
We use these work well get the small if you can fit key in and can attach the key to pouch and to chain inside pouch.
Mad to have a keyless car without a faraday pouch imo takes them literally econds go take you keyless car.
And most cars are stolen this way now.
Way more common than you would think.
OP hasn’t said what car it is. But if it’s a Toyota then even a faraday sack won’t save it as they just pinch the car without the keys anyway.
I’d just stick them in a biscuit tin btw.
Some disabled the keyless when you double lock from the key. I know the Clio did, and I'm sure the Puma does. No need for a gay key pouch then
Doesn’t the Clio have the proximity keyless go so you don’t even have to press a button or touch a door handle?
