Splinter Cell Double Agent (XB360)
Scutch
Car  G87 M2, Megane R26
Absolutely awesome game. Graphics, sound, controls, all superb.
I'm in the JBA Headquarters at the moment, Part II. What I was wondering was, has anyone managed to do that Mine Assembly task?! I cant for the life of me get the hang of it. Anyone have any tips? You use the Left Stick to position the Mine and the Right Trigger to control the speed. Damn its difficult :(
i got this but only played it for an hour or so. Good so far but R6:V will get hammered before i spend any time on this one
Its superb Ianaldo. The prison level, and the snow levels are amazing.
scutch the mine assembly is piss easy take it slowly
You cant do it slowly though Mike? You mean stutter the Right Trigger? Its not analogue so you cant bring it down gradually. Its either fast, or slow, and I cant get it in between without it stuttering and getting that b*****d Green light on the LS is a pain in the arse :(
i found it very easy iirc its easy to do within 3 minutes
the right trigger is analogue by the way or pressure sensative anyway
Ok cool. I'll give it another shot later :)
You get 25 minutes anyway, but in that time you have a lot of other stuff to do, including Voice Recordings.
Just remember you dont have to do all the tasks. Just do the task that will get your reputation up for which ever authority is the lowest
yeah just take it real slow...25mins for the whole level is more than enough...can get everything on there in about 15-17mins...
voice recordings are piss easy.
get the birds one right near the start of the mission, when you first meet her, and she starts walking to the mine thing, pop the recorder out... then once u done the mines go find that guy int he computer room and he goes on his radio, and record his then :z
Sorted Mike. Cheers. I applied only a small amount of pressure on the Right Trigger. I had no idea it was analogue/pressure sensitive :) Class. Now all I'm having trouble doing is recording people's voices without them spotting me. None of them seem to talk! How do you get them to talk and when I do hear them they are nowhere near me. Bah.
After a face to face with Lambert the new mission begins. Return the way Sam
entered. Climb onto the dumpster then over the wall. The restricted area ends
when you are back inside the garage. It is easy to sneak into the garage while
the 2 guards are talking. Enrica will enter and talk to you. She asks you to
follow her so you can do something for her. As you follow her she begins to
talk if you are quick Sam can record her voice right here without her knowing.
Once you reach your destination you are given 25:00 to complete as many of the
mission as you choose. CHECKPOINT
Enrica leaves and talks to Emile. This is another perfect opportunity to
record a voice. Point the microphone through the window and 2 of the 5 voice
samples have been acquired. In order to assemble the mines use the right
trigger to slowly (pressure sensitive) move the mechanical arm down while using
the analog control to keep the bullseye green. Its kind of tricky at first so
you may want to save before trying to get some practice before attempting for
real. Once 10 mines are created: CHECKPOINT.
Head back up to the main area of the headquarters. On your way there you should
run into Moss. Follow him. He will eventually stop somewhere and talk over his
radio. This is a perfect opportunity to record his voice. In my game he stopped
in the computer room and I was able to stand outside and get his voice
unnoticed. Go up the main stairs toward where you first encountered Enrica.
Jamie should be nearby follow him to the exit and up the stairs. A JBA repair
man has been repair the voice recognition system on the upstairs door to the
second level. Stand near the bottom of the stairs and record Jamie's voice as
he tries out the upgrade (Sweet home Alabama). Now really go to the room
Sam first saw Enrica. Pick up the pilot's body and go down stairs. Make a right
pass the table and move down the hall. Go right at the computer room and down
the stairs in the next room. Place the body over next to the other corpse and
a very simple objective is complete. If you would like to do the training
course or the firing range now is the time because we won't be back at the main
portion of the headquarters for the rest of the mission.
Go back to where you were working on the mines and use the voices you have
recorded to gain access through the door. At the top of the stairs turn left.
Notice the video camera above. An alert will be triggered if you try to walk
pass the camera. Therefore, jump and grab the pipe once you have cleared the
camera drop back to the ground. Hack the keypad on the door and enter. Enrica
is working at the table. Go around the table and squeeze between the sink and
the desk. There is a file cabinet in the corner, search it for professional
background info. Exit and cross the pipe again. Go through the door and up the
stairs. At the top turn the light off and open the door. Go to the right and
flip that light switch. Now move to the 2nd column of blocks protruding from
the wall and wait for the JBA member in the distance to walk by. Turn off the
light switch on the wall ahead (the light over the couch should go off). Now
walk by the couch and turn the corner right. Flip this switch as well. There is
a door on the wall opposite the light switch, pick the lock and enter, but
leave the door open. To the right is a guy sleeping on a bed. His voice is the
last voice Sam needs to record. Fortunately for us he has nightmares and talks
in his sleep. Be patient I promise he eventually talks, so be ready when he
speaks. While your in this room search both file cabinets for 2 pieces of
personal info. Back to the door, watch the guy on the couch. When he heads down
the hall leave the room and go left. (Depending on timing and if you did the
other objectives to this point, Jamie maybe nearby and make leaving the room
with the personal info a bit more difficult). Pick the lock on the door near
the end of the hall and enter. There is some personal info in the file cabinet.
Now go into the bathroom and out the window to the right. Head toward the truck
on the right and get on top of the crates. Climb the pipe and go over the rail.
Move down the walkway and enter the dark room. CHECKPOINT
Do not go near the desk. First go left and through the door. Now enter the door
on the left at the end of the hall. I assume this is Emile's bedroom. Search
the file cabinet for the fourth piece of personal info. Go back into the room
with desk. Beside the grandfather clock is another cabinet. This one has the
professional background info Sam needs. Now go behind the desk and to the safe.
CHECKPOINT.
Emile and Jaime will enter the room, so hide under the desk. Emile will open
the safe and show Jamie the blueprints. Jamie will leave and Emile will put
the blueprints back in the safe and sit with his back to the safe. Go crack the
safe, scan the plans and exit the way you entered. To complete the mission
return to the bathroom window that led you to the outside (this works so long
as there is time remaining on the countdown).
NOTE:
I had some trouble with Emile continually getting up and walking toward
the desk during the safe cracking mini-game. Upon trying the level again it
may be easier to go directly to the safe and hide when Emile and Jamie enter.
Then crack the safe while Emile is seated (he hasn't got up any of the times
I tried it). Once the safe is cracked return to under the desk. Emile will
leave and go into his bedroom. Once he's gone get the professional background
info. Go over to Emile's bedroom. Once the light is off he is a sleep and the
last piece of personal info is yours for the taking.
Completion of Primary objectives unlocks: Sonic Grenade - Attachment and
Hacking Device - Force Hack Upgrade
^ lol. Thanks for that, but because I've done the Mine Assembly first, and then saved, the timer is out of sync with whats being described above, so when I get to those points, the guys arent there or they are doing something else. Might just restart the level and go through that tedious Mine Assembly again :dapprove:
