yea, but the down pipes very rarely go!
Change it to cable its so much better. All you need is a throttle body if your using stand alone ECU.does anyone know how much hassle it is to convert fbw throttle to cable? is it more hassle than its worth?
The VAG ones.what gear boxes do you use on the 1.8t conversions ?
didnt matts car sell for summat stupid like £4500 in the end ? id of bought it lol but had just bought the 172cup at the time.
geesus where did you get it from?
use another box is the best option
Hope you have more luck than i do with mine.
nothing wrong with my box mate, just everything else...
Right couple of engine pics and one of the manifold being trial fitted.
Needs a bit of adjustment but looks the nuts!
And my new favourite place to sit!
Only 200 quid fo the pair!
looking good mate i may have some questions for you if you dont mind as i am planning on doing the same, just looking for the right shell first and then will set about sourcing the engine
i assume you are using the omex because the engine has fbw throttle? (sorry cant see it clearly in the pics) i am going the other way and using cable throttle and using standard 172 decoded ecu pinned up to car loom
its wayneclio16v iirc who has done it already, i have asked him some questions about the conversion and he has been really helpful
how you finding mounting up the engine?
can i be cheeky and ask your email addy so i can bombard you with questions?![]()
I dont know if you still have the 106, but because the saxo is very similar chassis, here's another idea http://www.zcars.org.uk/saxo/index.htm rear engined type R or duratec 2.3 conversion. It looks rank but I imagine it goes some.
They'll even do a hayabussa turbo! 0-60 in 3.3 seconds!!
Love the idea of a 1.8T though! very tunable and responds well to cheap(ish) mods and it's a solid lump.
EDIT
forgot to mention, goodluck with the completion to the o/p
There doesn't seem to be anything at the injector plugs :S using omex, anyone know of any problems it could be?
Fuel pressure may of been to high but surel that wouldn't matter too much and would sill send it in?
Going to ring Omex tomorrow as I think it could be a programming issue![]()
