Joining existing positive battery terminal to new wire.
Car  172, Tiguan
I'm in the process of putting the battery in the boot of my car. Having run the 4 guage wire all the way through the car into the engine bay i'm now looking for the safest way to connect the new wire to the existing positive terminal wire (which obviously still has the battery terminal on it!)
Whats the best thing to use to join the two wires? - or if I just bolt them together whats the best way to seal the join?
cheers
Yes tom. The existing positive terminal has the main wire going to it + 2 other wires. It then goes into trunking and dissapears into various things.
I'm only after an answer and some guidance on an easy solution as i'm no expert.
Why post here? just ask me!
if you going to the trouble of crimping terminals then might as well use a male / female shrouded type removing the need for bolts and insulating with tape == bit pikey
Wolf, that was just to protect the bare metal, even with shrouded you would need to tape up.
Jon, Next week lets answer our own question!
Thats nice that, shame you are going to cover it in tape.
(obviously you wouldnt leave it exposed if it touches anything thats spark time)
Going to bolt it together as first planned. Can't be arsed to spend anymore money. Next week lets spend a ton moving the battery 5 m.
Longer wheelbase means its more stable my friends! ;)
Plus think of the 30+ kgs weight transfer off the front wheels! I also have a new thing on the dash:
no need to tape them if they were a decent heavy duty m/f connector and shrouded properly, not that im familar with such for a car battery tho
The battery must weigh 10 -15kgs?
Weight transfer Thomas, thats 10 - 15 off the front and 10 - 15 on the rear ;)
Thanks for your help Wolf, ill do some hunting round.
that'll be the look on his face when he goes for the indicator misses it and gets rear ended by a gt3 rs doing 170 mph up kesselchen lol
to connect two 4 AWG cables together
get a 25mm2 through crimp and some heat shrink sleeving but you'll need to find a spark with a good crimper
dont beleive people do jobs like this on there cars with crimp connecters!
just a bodge way of doing things in my oppinion - solder them and heatshrink them.
to be fair crimps are probably better quality than the renault wiring is anyway, but still wouldnt be happy with the job doing it that way
every electrician in the land uses crimp connectors.
so i wouldn't say they are a bodge job and i'm not talking 2.5mm2 i'm talking right up to 1000mm2
