Mark, All levels are the same but for the scale to measure it must take the weight thus compress slightly, this will adjust balance and so less force will be measure as the others take up that very slight movement.
The four scales all compress together.
yes and that means you would need your back wheels higher than the others when weighing a front wheel as they wouldnt compress as much if they were on scales.
Did they tell you it wouldn't work too?![]()
