fiddled with the relay, it now clicks open, but im only getting about 10v through it... battery is still showing 12v, but is admittidly quite flat (wont turn the engine over many times)... anyway connecting this up to the fuel pump doesnt start the pump, so i need to do some more fault finding :?
also, trying to get my alternator light to come on on the dash.. if I ground the connector as beanie says the light comes on, but on the 172 alternator neither of the 2 pins on the connector go to ground
- should I just use the 16v alternator?
nick205gti, love the car!
looks just like mine except on ronals!
for a starter, you have to use whatever starter is matched to your flywheel (i.e the 172 starter) - the choice of gearbox should not matter at all, as the casings are all identical for the starters (im fairly sure)
So i'm using the 172 engine, 172 flywheel, 172 clutch, 172 starter and have just bolted a jc3 gearbox to it (from a 1.9D mk1 clio)
