Christopher
Z4M
No worries!
Exactly.
The coil pack bracket could be better, but it looks neat and tidy which is the main thing. Its for a road car FMP, not a track car so looks are just as important.
I realise you have that bracket though![]()
Unsure on fitment/mapping really, i'll let you know when K-Tec reply to me by email.![]()
i just spoke to them and they said that if u have a standard car then it will all bolt on and they will supply you with a standard base map for a standard 182 which will work out of the box. You can have it fettled with but they havent sorted that bit out yet hence why its still in development
thats cool. is it an omex ECU? could take it to get it live mapped elsewhere is suppose if you were'nt happy with it
david your itb kit was the best looking kit there and you dont need to cut the slam panel i like that idea good work
F/S x1 197. Wanted 172 Cup........ purchase said kit, rope in the Kevs @ Birchdown for fitting, me being helper/brew maker....... weekend later one braaaaap Cup
Boo yA!
The GDI package doesnt include cams guppy IIRC.
It does yeah, if you have the longer trumpets.
You dont NEED cams, bodies work well on there own fella!
I think you'l find you will need some sort of camshafts :rasp:
Mine will be running standard cams for the time being, so we shall see!
Exactly.
Pretty sure drive in and out in 1 day wont having it looking like how the demo car is. just loads of fancy pipes and painted etc.
On another note, i painted my old 106 gti engine white. bad idea
Exactly.
I’m curious, how would you make the coil bracket better? I imagine it was done to look as neat as possible with very little excess material so as to not add weight unnecessarily and to hit a pacific cost target. To which I would say it does all of the above very well. But I guess I don’t know anything about designing brackets so please educate me?![]()
Neater? Are you on crack? Makes the breather set-up so much better too.
Maybe you could have your B&Q hose and catch tank cable tied closer then?
No no, you're missing the point. Im not arguing AWT vs GDI, if GDI had made the breather I have, and I had the same set-up as yours, I'd agree that yours was much much neater, and better designed to do both jobs that its supposed to; Be a better oil breather and a coil pack bracket....
The thread is about how neat the Ktec install looks and you go all pissy when it was compared to the cars next to it, GDI.
SO yes, you hippocrate, it is getting boring.
