PH1 172 winter hack/track toy
Car  172 ph1 2.4 transit
Just got this as my new toy come winter hack !!
its lowered but not sure what springs they are but they are yellow and is also fitted with a K&N
Interior is stayin in for now !
Battery moved to the back, air filter directly fitted to throttle body, DS2500's all round, braided brake hoses, f & R strut braces and spare set of wheels and tyres for track in either yellow or blue then colour coded rub strips to match track wheels and then see where we go from there on budget etc
As saving/wanting a Escos next year !!
i know every one has said this , but when i got my ph1 it was lowered and i wasnt sure on what , they were also yellow and after close inspection they say apex on them . looks similar to mine . :)
A little up date
Thanks to Josh Hatton for these first of all !!!!
Also been out and bought this little lot
And also acquired this little lot via work
I just need to get inlet gaskets and core plugs then all the above can be fitted !!
Little update: Was up handy this morning so a little over an hour and a half and ive fitted both front and rear strut braces but found out my strut top mounts are worn so they will be on my shoppin list to get in next few weeks !!!
And also just ordered a set of TOYO Proxes T1R's for my 8X15 Comps which will hopefully be gettin fitted soon !!!
Will get pics up of Braces in the next few days with some better pics of the Comps too
Right Double update today !!!!
First of all went to the Autosport show and collected these from Tony who works at Compbrake ( i know both Tony & Ste via Passionford and a few shows ive met them at).
Solid top mounts
Second part of the update:
My bolt in tyre vaves turned up earlier this week as well as my Toyo Proxes !!!
It looks mint any scrub? is it on et25 all round?
Yes et25 all round its just catchin the top of the bumperon the inside so will trim it down tomorrow and will prob get arch's rolled just incase i happen to have a car full before the car gets caged !
Is it touching at the rear on the bumper fixing or the actuall bumper? 5 turbos used to catch on the rear bumper mount inside used to modify the fixing slightly. mint rims tho.
Wont go much lower due to width of rear wheels unless the rear archs were pulled out a good half inch !!
Tyres are 215/45-15's
OMG, my old car!!!!! :hail:
...to be stripped and turned into a track car, its final days of normality before it dies a death !! :dapprove:
Bet you wish youd a kept it now lol
See, told you that cam belt had plenty of life left in it. Lasted a good year after you had it :rasp:
