182 Cup
				What did you do to stop the rubbing at the front? I'm only getting rubbing when the suspension is compressed at higher speeds round a corner.
Today I've taken the wheels off to see exactly where it is and the arch liners were visibly scuffed just where the front bumper joins. I've cut that section of the liner, but just behind it there is a bracket with a single bolt through it. The bracket has a slight lip - will I need to bend this out of the way to give another 6mm clearance or grind it down?
What have others done?
