J
jakm15
Coming home just now and the pedal went past its usual braking point and only started braking right at the bottom, it started to brake at the usual point then stopped braking then only started again right at the bottom. Got out to check the level, is ok in between min and max, then put the handbrake on and that did exactly the same as the pedal went to where it usually does bit slightly then continued right up very high. Then set off again and went to reverse up the drive and BANG! The handbrake would not move up at all and the back brakes (I think) were stuck on tried again and BANG again. The handbrake went back to normal and so has the footbrake, handbrake is slightly worse than usual and there was a smell of burning when I got out.
going to have a look in morn and take it garage if I can’t suss it out
any ideas??????????????????
