172 Clio into an R5 GTT
James5_GTT
  R5 GTT
it was a split in the wiring for the ecu to earth
Found that the phase 1 172 loom had a split in the earth wire repaired it and then turned the key and she fired straight up only prob now is that the cam tensioner has come loose.
Anyone got the cam timing tools for hire or local to borrow?
  alien green rs133
2" flat bar with a u shape cut out of it :eek:
James5_GTT
  R5 GTT
  Vw caddy tdi
Very nice and thats coming from a 10yr+ 5 coniseur also, standard looking sleeper is the way forward. Side pipe I see had the exact same standard style rear bumper with no cut out on my raider.
James5_GTT
  R5 GTT
Well not much of an update as needing to sort the cam timing out, just forgot to mention no longer using the alloy Volvo alloy fuel rail due to now using the small stanrard 172 standard injectors and my modified phase 2 rail for an external FPR.
maynard
  ph2 172 track car
is that the cam belt tensioner? doesn't look good for sure whatever it is.
James5_GTT
  R5 GTT
Well she is now up and running I have taken her for a quick drive around the block all seems good apart from my 2k idle (no icv) I am adjusting idle by the accelerator cable for now
I don't think you'll get the idle right with the cable, you need to be able to adjust the stop on the throttle body. I'm not sure what it looks like, but are you able to fit an adjustable stop?
iirc there was an idle control valve for sale in the forsale section on here, as part of a 'breaking 172', cant remember where now though
  '92 172, Lotus Elise
now that you've got your tacho working, can you tell us what rpm it limits at?
do you have the speed sensor plugged in?
James5_GTT
  R5 GTT
There is an adjustable screw on the tb but mine looks the scree has been proper mullered I will drill it out and put a bigger bolt in
  Astra 1.9Cdti SRi
Excellent read, and im glad you finally got her up and running, have taken a few bits & bobs such as the Alternator solution tho, which i will be needing for my conversion very soon,
good job james :)
Max. engine speeds for a coolant temperature < 75°C 6,700 rpm
for a coolant temperature > 75°C in 1st or 2nd gear 7,200 rpm
for a coolant temperature > 75°C in 3rd, 4th or 5th speed 7,000 rpm
are you using the r5 speedo sensor or the 172?
James5_GTT
  R5 GTT
R5 speedo sensor still using the r5 box although i do have a 172 cup box in the shed if the gtt box isn't up for it. I will give it a longer run tomoz and if I feel confident with my conversion a bit if a canning obviously not exceeding speed limits
how does the r5 speedo sensor work... is it a mechanical cable like the mk1 clio with an electrical loom plug near the dials?
James5_GTT
  R5 GTT
cool
and you've wired in the speed sensor to the ecu?
Yeah it is wired up being checking out a few other threads on this conversion into a mk1 Clio and the signal has been unsucesful I am now thinking will mine work? What colour wire did you all use?
Also how did you guys wire up the temp gauge? And does anybody know what colour wire does what to the 172 temp sender?
James5_GTT
  R5 GTT
Fianlly got it on the road (Still need to take for a good canning though)
Things to do
Temp gauge,
speed sensor queries re above posts,
Find out about how the OE 172 rad fan works (is it constantly on or does it come on when temp switch activatded???)
have a read through mine and f0xys thread for the temp gauge solution. we plumbed in the mk1 clio dash temp sensor in addition to the 172 item.. i presume you can do the same with the 5.
the 172 rad fan should work properly provided you have the relays in place still as well as connecting up the speed sensor and 172 coolant temp sensor to the ecu... atleast mine does anyway :D
mk1 coolant temp sensor into mk2 thermostat housing
drill through the housing and slot the sensor in. then secure it from behind with a suitable thin nut. also worthwhile using some sealing washers and silicone to stop it leaking :) - mines been fine up till now. careful with your placement as you will need to leave room for the coolant hose
the mk1 clio sensor has 2 pins, one for the warning light and one for the gauge. just hooked them up as they originally were!
the mk1 used an additional sensor for the ecu...
James5_GTT
  R5 GTT
Cheers for that I was going to do the same thing but use my orginal GTT temp sender again this is a 2 wire connection and i still have the original connection in place so just be a case of drill and tapping and then extending the cable to get it fit.
I am using a standard 172 phase 1 loom so I assume that the fan should work as normal then as it would have all the above you have mentioned already in place.
