The everlasting ph1 ITB Build **GREEN-BUILD STARTS AT PAGE 100**
Re: someph-ing different...........
no you dont get the locking tools in the kit...
you need the cam locking tool, pulley locking tool and the crank locking pin to do it properly :)
i think i have sourced one to borrow,
otherwise jord can you advise were i could borrow one from, don't fancy renault prices on that
£140 for the whole lot of tools I think from renault
or quite a few people on here have them, they may rent them out to you.... Fred, burp maybe, cant remember who else
I hope your not copying me! Looks really good though. I love the yellow calipers on the black rims. Good job!
Thats a sexy bay man!! Love it!!
behave.....if i wanted it to stay clean constantly i would polish it.....
appreciate mint bays but no thanks, i want hassle free
another thing to check off my list...
received my catcams today.....yay
so before thursday i need oil and coolant...job done then
Got the crank and cam locking tools if you need a lend but dont have he pulley one anymore. Sold it to Matteh
bootifuwl, you going to get back on powerstations rollers afterwards to see how much difference the cams make?
will be interested to see how much change they make
you got all the tools? don't forget to order new cam seals for the top end (comes as a kit from renault, complete with new VVT pulley bolt and seal, plus you'll need to order exhaust cam stud and nut
i have the cam locking tool and the crank locking pin, not got hold of a pulley locking tool,
i spoke to lemonnobby and he sorted me with all the parts he said i would need, don't think i have the exhaust stud and nut but was told by someone else that the old one should be fine to re-use
^no chance on gods earth! get new ones, you'll struggle getting the stud out the cam without causing damage, a new stud and nut is under £5
right ok, will get one sorted, by chance do you know the part number?
you think i will be alright without the pulley locking tool?
you have to use the pulley locking tool to get it right, as the pulleys flex/move when tensioning/tightening
you'll never be able to remove/refit the pulleys without it!
stud - 8200778847 £2.41+vat
nut - 8200545692 £1.81+vat
Awesome mate. Cant wait to see this.
Wouldnt mind meeting up soon to have a looksie?
Also how much was cup alternator setup?
My cars had aircon pipes and rad, etc removed but the pump is still there because of the aux belt.
pm'd you about meeting up dude
the set-up, well i got the alternator second hand off here for £80 unused
the mounts i was told were hidden in a laguna in a local scrappy, i got them and couldn't get the PAS pump off so took that too, all for £15
just ordered the above to be in tomorrow
new part numbers
stud - 8200778847
nut - 8200793248
Head seal Kit - 7701471629
copied from freds pm to me, thought i would post it on here as people may find it helpful
Head Seal Kit - 7701471629 -£21.59+vat
comes with inlet and exhaust (timing belt end) cam seals, new vvt pulley bolt, new vvt pulley cap cover, new exhaust pulley nut
stud for the exhasut cam - 8200778847 -£2.41+vat
cam seals for the gearbox end are included in the gates power grip cambelt kit, seperatly (if you use another cambelt kit as i am) they are 7700106271 £6.87+vat and 7700274026 £3.69+vat (seen below)
my kit for the work to be done, again some may find it handy...
cam locking kit and cam locking pin (thanks danlp6 / dunlop)
seals as mentioned above
alternator belt
cambelt kit (cup)
and nothing to do with the service, i posted these a little while ago
turns out i got the stud length wrong, the above studs were sent back and i am now the proud owner of 80mm studs...yay, these will also go on on thursday
i will be photographing all so will update thursday / friday i expect
Hmmm i have just done a stud conversion.
Those black nuts look the dogs dude!
Where can i get? ;)
