197 Coilovers won't go lowwwww???
Mr Burns
  Swift Sport
Got some KWv1's fitted the other week, handling is awesome.
It was sitting a little high at the back so I took it to Joe (Pepsi) for adjustment.
Turns out the coilovers are already at their minimum setting and as low as they'll go, so Joe took the spacers out to get it down a little bit more.
Does look better tbf (thanks dude :))
...But surely the idea of coilovers is being able to slam the car on it's arse if required!?
Any idea!?!?!
Cheers,
Ste.
The Boosh!
ClioSport Admin
  Elise, Duster
Good idea Luke, seems kinda weird though that they won't go any lower :S
Any idea how and where I could get custom springs??
Yes mate, there is a place in sheffield that fabricates them to whatever rates or whatever you want.
http://www.coilsprings.co.uk/
It costs about 50-60 quid for rear springs depending on the spec you want. They make springs for race bikes etc so they know what they are doing. ring them up and have a chat
Coby.
  XC60-R.......V40-R
Coilovers aren't about going stupidly low.... They are about Improved Handling/Adjustability
ForceIndia
  Gentlemans spec 200
What a waste. Spend that much on suspension then drop it so low it won't handle.
Gaz_
  Extreme mode
knows ;)
Not the best pics, but if required i reckon you can go another 25mm at the front and a good 15mm at the rear easy. I Had to raise mine up from the first time we lowered it. At this hight no scrubbing/rubbing what so ever, and it gets driven hard down the local B roads ;)
Pep
Living Dangerously
  M2,XJS,S1000RR
Call round next week Ste, I'm a dab hand with the grinder so I'll just lop a couple of coils off for you. Job done.
M
mini-valver
If you're having it CW'd, you'll need to raise the rear anyway or you'll run out of damper travel at the front, rendering the suspension useless!
Coby.
  XC60-R.......V40-R
I like Low Cars but I wouldn't have stumped up for KW's if it was the main reason for getting them.....Thats why I roll on GAZ's ;)
  172 Ph1, Lupo GTI
we can look at some custom Eibach ERS coilover springs if you like. shouldn't be too expensive and is a name you can certainly trust..
Mr Burns
  Swift Sport
Thanks for the advice, I'll see how I get on. It's not a problem to raise it up a bit! :)
Nah mate I'm happy with them, I bought them for trackdays. I was just suprised that they didn't go lower!
Interesting! I'd certainly like to know more :)
  lift number 1 @ btm
kw have a whole range of springs and i'm sure they work on an exchange basis.
maybe try calling them?
ForceIndia
  Gentlemans spec 200
Fred knows a KW supplier IIRC, might be worth an email. On a side note, I've been told that KW don't do V2's for the 197, but read an article in Performance Tuner where they reviewed a 197 on V2's?
Mr Burns
  Swift Sport
Thanks, might just do that :)
That is odd tbh, I have no idea myself. These are only poverty-spec V1's anyway! lol
ForceIndia
  Gentlemans spec 200
I've not driven a v1'd car, but the v2's are great. Someone's seeing if they can sort out in car adjustability for the dampers:cool:
Mr Burns
  Swift Sport
Nice!
I've gotta get some decent tyres before I can give the V1's a more accurate verdict, I made the mistake of getting Kumho's on the cheap!!
Handling is sharper and the ride is much improved over the H&R springs I had previously, hopefully I'll get to give it some proper abuse soon! :)
Mr Burns
  Swift Sport
Ooooh, Which ones are they? My mate has just had some Hankooks on his 197 £58 a corner and said they're great!
  lift number 1 @ btm
this would interest me too!
i've seen a motor operated system that fits to the top of the strut, fine for the rebound, but the adjuster for the bump on mine is on the bottom of the strut..
if you find anything out please let me know :)
Mr Burns
  Swift Sport
Haha! I've actually seen that before, your post no doubt lol!!
That's a good enough recommendation for me, when are you on track next?
ForceIndia
  Gentlemans spec 200
Are yours V2's?
ForceIndia
  Gentlemans spec 200
Abingdon nr Oxford, 23rd Oct. Going with w3eeb off here aka Mr Brawn GP.
  rs r27
hi to all, i've the same "problem" and next week i change my kw v1 with H&R coilover ...
now: 31.5cm @front and 33.5 @ rear
front is ok, bur rear i want 32!!
i think to change the spring but i don't know if it's a good job so i sell my kw and change with H&R
