Wests Widetracked Flame Red DCI 80 Sport Rep
  2002 Clio 1.2 Extreme
Re: Flame Red DCI 80 Sport Rep
the car is looking amazing, well done mate, just went throught the whole thread and was thinking he needs an rs grille then bam it happened lol
  Discounted 1*2 parts
Yea it took a while to get my arse into gear and order one!!!
Fitted the spacers to the rear coilovers at the weekend
Prefered the look of it without the spacers but you couldn't take people in the back without the arches rubbing on the tyres!
  Disastra Coupe
Excuse my laziness for not searching, but did it not have them at all then? Is that not dangerous? (Don't mean that arsey btw, just a question lol)
Tunst
  Focus ST225, Focus E
No, people often take them out just to get that extra little bit of low
this is looking awesome now!!
just needs a DCI 100 turbo, Intercooler and remap to finish it off!! i miss my old mapped 100 :(
Although i've been saying the whole way through this project i'm not going to tamper with the engine, I am now considering a few DCI 100 parts :S
  low and smooth 1.poo
haha do it. put a cheeky remap on it, and it will be quick like
Yea a little more poke wouldn't go a miss.
Is it just a case of bolting on the DCI 100 turbo and intercooler. I've read over on the dci.net website that the internals are also different?
Martin_172
100 internals are stronger as renault apparently threw a few pistons thru the block while stress testing the 100 engine, however im not sure how stressed these engines were!
few guys on the forum running mapped 65s around the 100bhp mark, id imagine a mapped 80 with the better injectors would be good for 110/115bhp, turbo would be your limit.
pass on the 100 turbo not sure if its a straight swap or not, however its an awesome turbo! my 100 @ 130bhp/190lbft used to fly! until the clutch started slipping with the torque)
Thanks for the info - may have to join up over on cliodci.net to get some more info :)
Was going to carry out the rear disc conversion on the dci today but a collegue of mine mentioned that the master cylinder may be different between discs and drums - this put me off trying if it wouldn't work.
Anybody done the conversion or know if it is possible before I waste my time and effort??
  Clio 2.3 dCi 80
The master cylinder is the same, don't worry.
a renault "guy" told me the same, and i bought an RS master cylinder, for nothing .. the original one work with the rear disc.
But, il you have on the front the RS caliper + rear rs disc, it will be good to mount a RS master cylinder.
if you keep the original dci, the pedal will be "looong", you understand? :)
  Clio 2.3 dCi 80
I forgot : (master cylinder size)
dci 20mm
rs 22mm
big brakes conversion, we generally use 23,8mm with Brembo megane RS caliper.
so, it's a good thing to change it, but the oiriginal dci work :)
I have the RS calipers on the front and the brake pedal travel is very short - i.e. you don't have to press the pedal a long way for the brakes to work
  Clio 2.3 dCi 80
i used to drive dci calipers + rs master cylinder and it was really short and nice (i thought), when i changed my dci caliper for RS caliper, it seems to me very long. Just a different point of view i think ;)
Thanks for your answer about the rear spacer coiovers, do you have link to buy it?
The spacers/adjusters came with the coilovers
Mickb
  van low and 1.6 16v
ive got sport brakes on the van. with braided lines. pedals doesnt seem any different.
Got the spacers through this week.
Went to fit them today but they won't fit on rear hubs, only discs. So I'll be getting the rear disc conversion done asap :)
delta mics? if so I would advise you got some new bolts, and not to use the ones that come with them.
Why dont they fit the rear hubs. I ran 25mm with my rear drums for about 2days and fitted fine.
What is wrong with the standard delta mic bolts??
When you put the spacer on the rear hub it doesn't butt upto the hub face
I've heard too many bad things about those bolts. Including this: fail
Do they tighten at all, or is there a small gap about 2mm between the drum? Might be different on the dci I guess.
Ouch :eek: thanks for the heads up!
There is about 2/3mm gap between the back of the spacer and the hub face, whereas when i tried it on my mates 172 it fitted perfectly
Yeah I had that gap on mine. Not sure if its to do with the face of the hub, however I as long as the bolts are correctly torqued they should be fine. If your getting the disc conversion for the rear, you may as well just wait.
Yea just didn't look safe having the gap, so will wait a few more weeks until the rear discs go on :)
Replacement centre cap arrived today as one went missing at an Oulton Park track day when the wheels were on my old 172!!
