100% complete 172RWD! - updated
Some new parts have arrived yes
And shall be fitted soon.
Giving up on the v6 pedal box.
Going for a different route.
After clutch is done .
Next stage is last bit of wiring in and
Then a new custom exhaust system.
Then should be ready for some sort of start up mapping.
It's been there and back lol
Atm it's around 85% again.
Difference now being done better and proper.
Little bit more power .
Picking some bits fir the car this sat!
Secondhand parts.
Front bumper
Wings
And poss a bonnet.
Got a few bits to put on eBay now.
Front seats
Inlet plenum
Lower inlets x2
Exhaust manifold
STD injectors
Fbw throttle fly
Cable fly
Throttle pedal
Door cards front.
Yes indeed.
Small tear close to top near release handle for passengers to get in rear.
Not that mine now.
Going tO need a much bigger fuel tank.
28L plus 2L swirl pot
Won't last long .
Might good idea to add some front ballast too.
65 pages... feck, I'm starting to wonder if the world will end before this car gets finished.
Chop Chop.
Secondhand parts.
Front bumper
Wings
And poss a bonnet.
Front seats
Inlet plenum
Lower inlets x2
Exhaust manifold
STD injectors
Fbw throttle fly
Cable fly
Throttle pedal
Door cards front.
At the moment I have only got a 6gallon
Tank.
I'm going to add an extra tank ontop the other.
I can fill bottom one separate to the bigger
Top one.(12gallon)
So all together 18gallon 90L?
Should make up for no weight at the front.
Going to add a charge cooler tank too
2gallon.
Lol love how the front end sits against the wall there Stevo, looks like there should be a desk or a piano behind it
Yes mate looks good.
I only want rear 3
Going to have scoops/vents fitted for rear engine cover.
Don't want to lose front elec windows .
Here's the scoops/vents I want
Going use one each rear side window to feed some colder air to the engine bay as it's also being drawn out through the subframe at the bottom.
I'm going to make some sort of heat shielding from exhaust heat and bay area.
Loads of space helps.
Just noticed this, sounds like a right mission, fair play!
Although at first glance I suspected either a V6 rep, or a front-engined, rear-driver.
Keep up the good work fella
Just waiting for an exhaust elbo then exhaust will be finished.
Single exit.
Chargecooler rad fitted
Oil cooler fitted
Turbo fitted
Plenum etc fitted.
More soon
Just spent half my life reading through this! Awesome project; huge respect! I wouldn't even know where to start something like this :o Can't wait to see the finished product! :p
