Sir_Dave's Trophy. 1 x Miley Shed.
  Clio 172, Nova Turbo
Re: Project 172k Trophy, & its endless track abuse
where did you buy the pro race 3's from mate they are awesome wheels. my 172 is on 124k and still going strong
love the fact t had a cambelt after 11-12months mental mileage
Sir_Dave
ClioSport Trader
Well, the Trophy is currently on holiday at JMS, so thought I’d look through some pictures …. already posted these in the track day thread a few weeks back, but meh:
Also managed to acquire a power graph from just before I bought it …
One of my centre caps has disappeared as well, so need to get hold of one asap really.
Sir_Dave
ClioSport Trader
Looking sl*gishly good as usual!
Any more plans for it?
Not really, just a shed load of maintenance work really, currently in for cambelt/aux belt/de-phaser, & potentially new PAS pump/alternator as one of them most definitely died at Donington. It's all in James'/Tom's capable hands at the mo ...
Getting the aircon delete kit fitted as well, it hasnt blown cold since i bought it anyway, & theoretically it may add a little power/reviness to the engine. I guess it'll also be nice having something shiny on the car, certainly wont be the paint anytime soon ;)
Then maybe some Koni adjustable rear dampers & de-pin the fronts so i can mess about with the suspension a little more. With the addition of R888's for my next track outing, it will be nice to have a little additional stiffness at the rear i think.
Sir_Dave
ClioSport Trader
Little update as the car has now been on holiday for a week.
Not because JMS are slow i might add, but because i told them to take their time, im in no rush to get it back. Purely as it only sits on the drive gathering dust till the next trackday :evil:
Work completed so far:
  • Compression Test - all fine, was pretty good across all cylinders apparently.
  • Cambelt & Aux Belt change - had done 4 yrs/100k since the last one :eek:
  • De-phaser Pulley - had finally started to rattle a bit after 174k
  • Rocker Cover Reseal - was leaking, literally everywhere, i used a 5L can as top up.
  • Pure Motorsport aircon delete - didnt work anyway, less weight, faster pickup?
  • Coolant change & thermostat - again, had done 4 yrs/100k since last change
  • New NGK PFR6E10’s - by the look of them, they had done 174k & were causing a misfire at 1.8k rpm. My solution was to simply keep it above that. James said i was a bad man.
  • JMS Remap - already had RS inlets, so it seemed rude not to really, obviously wont be getting the ktec one now, so will see if someone else can take my place ...
Cant wait to get it back & take it for a drive, should feel noticeably different compared to before :D
Have decided that i'm going to clean it as well. Its rank atm.
This car makes me feel so much better, about the mileage on mine.
  Saab 93 Aero Wagon
[*]New NGK PFR6E10’s - by the look of them, they had done 174k & were causing a misfire at 1.8k rpm. My solution was to simply keep it above that. James said i was a bad man.
I thought my sparkies were knackered, and James said they were the worst he's seen as they had done 72k, but yours.......man im suprised you didn't need 1.21 gigawatts to make those buggers spark!
And i guess when you say 'I' that means 'Ollie will be cleaning it once I've picked it up from JMS' ;)
  Lotus Elise
Sounds entertaining Dave, have you noticed much of a drop at the front with the sportlines fitted?
Sir_Dave
ClioSport Trader
I had meaned to change them, honest :eek:
Well, if you're offering .... it really could do with a
then a
Not especially, maybe 5mm max. with about 10mm at the rear. Then i pulled the interior out, which raised it back up again ... needs coilovers for looks and if/when i strip it completely. Unless you/Fred ae working on something else ...
Chris205
  Many Things
Nice work Dave that sounds like a pretty penny will have been spent with the lads at Jms. When I take mine down for some work I will give you a heads up and meet up at the garage for a bit of trofail chat ;)
Let me know how it feels with the aircon removed.
  Megane 225 F1
I'll take your place at K-tec ;)
You're actually going to clean it?
  Saab 93 Aero Wagon
Of course he won't. He'll just keep driving it looking like a ditch with trophy stickers on until I get so annoyed that I'll attack with a Karcher. It's his usual ploy.
  Megane 225 F1
If I drive to you, will you get sooo annoyed at mine that you clean it? ;)
TimR26
South Central- West Berks
I like that solution :approve:
Good choice on the remap better than messing about going down to Ktec, I was really pleased with my JMS remap :)
  Mazda 3 MPS Mk1
is it wrong that this is my favorite car on the forum???
Sir_Dave
ClioSport Trader
Lol, cheeky sod!!! True though ... ;)
Dave. <3 you. Guess uve been drinking like i have lol. My Trophy is a shed. Although, perhaps thats half the appeal ...
  Mazda 3 MPS Mk1
its like an old whippet dog, a bit whiffy,a bit haggered, but you love it, and its still quick as f**k lol
Sir_Dave
ClioSport Trader
I though that on this note, i should make a rather large update :D
Firstly, thanks to James & Tom at JMS, despite having to be on the Eurotunnel at 6am this morning, James was bleeding my brakes at midnight last night - mostly thanks to Boosh bringing in a last minute brake related emergency/f*ck up i might add ... IR tired.
So, as mentioned previously i was having the following done:
•Compression Test - all fine, was pretty good across all cylinders apparently.
•Cambelt & Aux Belt change - had done 4 yrs/100k since the last one
•De-phaser Pulley - had finally started to rattle a bit after 174k
•Rocker Cover Reseal - was leaking, literally everywhere, i used a 5L can as top up.
•Pure Motorsport aircon delete - didnt work anyway, less weight, faster pickup?
•Coolant change & thermostat - again, had done 4 yrs/100k since last change
•New NGK PFR6E10’s - by the look of them, they had done 174k & were causing a misfire at 1.8k rpm. My solution was to simply keep it above that. James said i was a bad man.
•JMS Remap - already had RS inlets, so it seemed rude not to really, & i had already decided against the other, free option
•Bleed brakes - they've not been right since Donington
•Gearbox Oil change - probably never been done
In addition, to cure the whirring noise a new valeo alternator was fitted (exchange from GSF as the Renault item is now £400 lol), along with a new PAS pump - its been struggling occasionally of late, ie getting pretty heavy sporadically, so thought i might as well get that changed at the same time.
My thoughts? Its like a new car, obviously the whirring is no more, it idles perfectly & i dont need arms like Arnie to turn the wheel. Most importantly, the engine, oh the engine. No more hesitancy below 2k (from f*cked spark plugs), sounds wonderfully smooth (rattly de-phaser is gone) & it pulls like the proverbial train (partly due to a new Pipercross filter i guess, instead of an ITG that looked like it had been dragged through a lake. Obviously its been remapped, but having had a mapped clio before, id put the overall improvement down to a combination of the work done, along with the pièce de résistance, the Pure Motorsport Aircon Delete Kit ...
Not only does it add that little bit of shinyness to an otherwise average engine bay, but yes, it does make a really noticeable difference to the way the car drives. Obviously with all the other work that i've had done to the car, it would be silly to talk about power & speed, etc. But wat is noticeable is the improved eagerness to rev & lower inertia of the engine, a blip of the throttle really is a blip now, with it swinging round with an almost 'vtec' like quality.
James said that i would realy notice it the 1st time i heeled & toed, & i did when the revs jumped about 1.5k more than they usually would on a typical 4th to 3rd downshift!
So, in effect, i've had a lot of work done, spent a lot of money & ended up completely falling in love with my car again. Thanks guys. :eek:
And now, some pics :approve:
Before (note the oily rocker cover):
After (clean rocker cover):
Before (aircon stuff):
After (no aircon stuff):
Minging old alternator, aircon stuff:
Shiny things:
More shiny things (a great piece of kit):
Have now abandoned the Beemer at Mike's and will be driving the Trophy for a few days, quite possible with a huge grin on my face!
Rob
Good stuff Dave. Car's always feel so much better after a service, but after all that you must feel like you've gain 20hp!
Hixle
Hi Kiss Luke E****
  E90 M3
:approve:
Great post mate, can tell you're genuinely chuffed. Mine's going in to the garage for some work and a service next week - I hope to have that 'new car' feeling too!
Sir_Dave
ClioSport Trader
Most definitely!! More like 25bhp though, it has been remapped as well remember ;)
:approve: x
when did you get home ya doughnut ? Late o'clock like me no doubt!!
:approve:
Oh, massively chuffed!! Havet driven it in anger for over a month either, & being used to the 320d, it felt flipping amazing to be back in it. Has cost me a small fortune this month though. Cheap Trophy = not cheap Trophy anymore lol.
  Megane 225 F1
Ohh shiny things. I like shiny things.
Cereal question. How much did your wheelies cost you? :)
SharkyUK
Nice one, mate... glad you are in love again with the frisky redmobile. :D I'm looking forward to being reunited with mine on Sunday after a 'difficult' period in our relationship... LOL!
The Boosh!
ClioSport Admin
  Elise, Duster
Got back about half 11 mate. I was up at 5am yesterday morning so it was a long day.
James did a cracking job by the looks of it though, and Tom squeezed me in last minute so I can't complain!
Sir_Dave
ClioSport Trader
£342 delivered from Demon Tweeks, quite a bargain i thought!!
Oh, you'll love getting back in it, and after all thework you've had done, you too will definately see an improvement in the power/delivery!! Like a new car, amazing considering the miles she's done now ... and yes, after all this love, my intention is now to clean it.
Ooft. I got home at 1am this morning, up at 6.30 to come to work. Ouch :sleepy:
  TrackCar & F30 330d
Good to hear that the removal of the ac gives a noticeable difference. Hopefully I'll feel the difference with the removal of 40kg and ac & pas :)
  Megane 225 F1
I THINK you may have just persuaded me to buy some pro race 3's instead of getting my F1s refurbed.
TimR26
Glad it's all sorted now. It'd be interesting to see what it now makes at SRR.
  330i. E30 Touring.
It seems we all had a late one because of the JMS cants. x
TBH, any excuse to spend an evening with Luke suits me.
  Saab 93 Aero Wagon
It seems we all had a late one because of Tom. x ;).
A JMS Last minute.com evening was had by all, but as ever, all came good. Personally i blame it all on Luke and his DIY mechanical fail. ;)
Im interested to know how the hell Tom got on this morning. Driving to the Alps with pretty much zero car prep, no idea where his passport was, and a distict lack of warm (and clean) clothes.
Gally
Awesome Dave! Miles me nothing once it's had enough re-work done! :)
Let me know once you're selling! ;)
  Lotus Elise
sounds good, why didnt you go for a cup setup if you were getting a new alternator? Also does the light still come on when you turn your AC on?
