As bomber says we use as much as 45 litres in some races. if we ever did the 1 hour race at Spa we would only just have a enough with a standard size tankI've not really looked at a clio fuel tank or the rules.. do you have to run a standard tank in this series? Are you allowed to modify it? I know a few Pug 205 owners who were cutting down their tanks and plastic welding them half the size. Now could you effectively cut and seal off a significant part of the tank so a full tank is just enough for racing, but also moving bias towards the passenger side? Or do this internally so not obvious..
with 35kg of ballast (to simulate 40L of fuel, yes i went about 5kg over, but the tank is drivers side biased) and me on board (cira 80kg depending on how well my morning drop off goes) the car is 1015kg
bit of a tw*t to do this one as we have 2 drivers experiencing 2 fuel loads, so we have to try and balance the understeer/oversteer associated with fuel loads, so trying to get the front/rear weight distribution right with/without fuel PLUS the camber, castor, toe corner weights yada yada yada
basically a never ending story, but i love doing setups
we found why the front left was locking up/spinning its tits off, it was missing 90kg of downward pressure Vs the drivers side - not far off a std cup infact
1ltr per min does not get you very far.
Do you just brim it Tony, or do you run a calculated fuel load?
Good stuff. Have you got Quaife doing the crownwheel pre fitting?
i see the updaet on twitterwhen is brands?
Done and finished,all ready to go in the car.
3 word update...............
Quaife, mmmm, Nice
