Can anyone make me some bits of metal for my top mounts?
Car  172DD Cup
bit vague, but can anyone make a couple of metal rings? how much would this sort of thing cost?
thickness = 1mm. holes are to fit M8 bolts, i can confirm distance between bolts later.
it's to go around the top of the bodywork on my solid top mounts. like what the strut brace does in this pic.
cheers, kris
ok mate yes please.
the holes are 8.5mm diameter and they are on a pcd of 62mm with equal length between them. i'm gonna try and draw something up in office(!) don't laugh.
two of these please
width anywhere between 1-1.5mm. you can see in the top photo what its used for, so whatever you think is best.
Just as a big washer. It will sit flush on the body around the top mount. I don't have the strut brace on mine. Just needs to be washer thickness really. Don't want it too thick as ill have less bolt holding the mount in place.
Sent from my ZTE-BLADE using Tapatalk
Surely you could line it up with the bottom of the hole as I though it was just the top corner of your top mounts that had been ground away?
Yep, its ground away exactly where the top right bolt would go
hi mate pm me im aircraft sheety so this is what i do, shall i supply material also meet you in farnborough or near pm ?
