Query RE fitting a Boss/ aftermarket wheel
The Boosh!
ClioSport Admin
Car  Elise, Duster
I'm in the process of threading the wires through the boss to bolt it on.
I've done the air bag wires and the black and red wire (horn I think).
What do I do with the last connector? It's a black square block type thing. No way is it fitting through the hole in the boss.
Help? Mk2 ph2 btw :)
Pic attached
It will fit through mate, i've got an OMP one and its abit tight but it does go.
Make sure your steering angle sensor is lined up properly mate, it gave me loads of problems when mine was out.
How do you know which way to line it up lol
In the top left hand corner of the sensor there is a little window. When you turn the inner ring of the sensor you will movement in the window, you have to work it out from that. Its pretty easy to work out i'm just sh*t at explaining things lol.
It will not fit mate! Sorry to tell you the bad news! I had the same problem, for some reason the omp boss does not fit, had to send mine back and got a MOMO one that fits perfect
Problem with the omp is the hole for the wires to go through is simply not big enough
Ben have I broke it massively?
Did you try fitting the biggest one through first? so the other wires werent in the way? Before you broke it anyway lol..
My OMP boss fitted mate.
Why?
Are they easy to replace if
It's broke? How do you know if
It is broke?
What are my options with the CC being broke if I put my standard wheel on? :(
I think this is what has happened. I didn't realise there were different kinds for the Clio. Hole was too small but I couldn't tell by looking at it if it was going to fit.
Trying to prise it in has knackered the ribbon wires for the cruise control.
Also i tried to line up the spinning sensor thing, thought i did it right but the TC light is still on so either i've done it wrong or i've broke it.
You shouldn't have broke it mate. If the steering angle sensor is set right and you still get ESP + serv light's you will probably need steering angle reset to 0 degrees. This happened to me and it had to go to Renault to be sorted, cost me £50.
Ah well!
I'm going to need to buy a squib
momo boss
Have the angle reset
Just going to pay mick from diamond motors to sort it out as I cba with it.
I think we have learnt a valuable lesson here... Luke should not 'work' on cars!
Poor Luke :(
I also need to go and see Mick for some Clip diagnostics, when you going down lover?
Ah well!
momo boss
I prefer just to get work done for me, that way I know it will be right and i'm not going to ruin my car. Also i can drop my car off in the morning and it can have what ever work im having done when im sleeping, then i wake up and my car is back outside my house. :cool:
lol at this
The OMP will fit Luke, its the fitter thats the problem ;)
Mine was really tight, but it still fit fine.
lol at this
Mine must have been different then mate because there wasn't a chance in hell that the CC connections was going to fit through that hole. No way.
I've bought a momo boss now anyway. I wouldn't recommend OMP boss for RS cars with cruise control. If you've not got CC then it's fine
Poor Luke :(
Hopefully Friday at some point mate - late afternoon
Does the CC connector unclip like the airbag ones did?
Oh and where did my post go. I made the "like a boss" joke first :(
