Mk1 Clio to 172 Conversion engine mounts
Car  Clio 1.2 1995
Before i go out and make the mistake of buying something that will be an arse to fit into my project car i wanted to ask will a 172 engine fit into a standard 1.2 mk1 clios engine mounts or will it need 172 mountings or is it just an arse and should use a valver?
cheers
James
Yea all the same except the rear gearbox maybe different and you need to drill a hole in the subframe if using a 172 gearbox
