Fletch's 150k 172 Project..
  Mk2 Escort
You cant get shot of it. Its the only car i thought would be in team anorak till the very end. However you would be dangerous in an r26.r (in a good way).
Fletcher
Sad times with the fletchbus mate, however R26.R is a very good shout!! :)
Yes guys sad times :dapprove:
Yes Russ. If I had somewhere to store it I probably would mate.
Could you see anything obvious when you got back Fletch ?
Not really mate. The aux belt most defiantly was/ is catching against the pre tensioner ( spring) something around that area has failed. my biggest concern however is where the oil is coming from.. :S I checked the dipstick and the oil level is still spot on, and the car was pulling as well as ever on Sat.
I really could do with getting the engine out and having a proper look, or getting in to a garage for a full check.
Fletcher
