Flame red ph1 172 {take 2}
In my opinion, everything you've done to the car (with the exception of the alloys, love turbines) has made it look worse. I think most people prefer ph2 rear lights to ph1 but if you wanted all red I can see where you're coming from. What I cannot comprehend is why you would de-colour code it?! Looked much better with ph2 side strips! You could've atleast cc'd the ph1 side strips if you do have a jihad against ph2 bits on a ph1
Because he is a purist ph1 fan.
Car looks awesome, good work :)
Lovely car.
You dont have any more info on removing the A/C do you ? I have the cup 'setup' waiting to go in.
Just need a bit of a guide on what's involved.
Cheers.
It's personal prefrence really mate, i like my ph1's non colourcoded (Bar the handles) and mostly original, its just the look i like. I would like to stress that this is very much a WIP, its no where near finished yet, i just like to keep a up to date record of how it's changing. .
I've had one with colour coded side strips and i liked it but i didn't want this one looking like a clone of my last flamer Y534 which was more a OEM+ kinda car. I think that the dark strips go well with the dark wheels. I also run my partners car with ph2 bits, i just mix and match to what i like. (see pics)
What alloys have you got on the front here? Haven't seen any like them before, quite like them
The alloys on the front are Ph1 19 16v alloys.
Cheers Dan, I do like a ph1 to be mostly ph1, but I am tempted by a cup spoiler. :o
Lovely car.
Cheers mate, its getting there.
What is it you'd like to know?
From what I've read/tried you'll need: Cup alternator, cup alternator adjuster, cup main alternator bolt, cup upper and lower mounts, cup lower mount bolts (some bolts can be reused to fit the smaller of the two mounts).
Things to remove: Alternator, alternator top brace, air con pump, aircon lines and rad, lower mount with auto tensioner.
I was really surprised with all the bits that were coming off, I can get a pic of all the bits removed and you can compare as you do yours.
The powersteering pump needs to be moved down a fair bit and you do need to reshape a bit of powersteering pipe, where it goes into the pump and then onto the flexi section. I've looked at a fair few pics of peoples and everyone seems to do it a different way, See what you think suits yourself. From what I've heard you can change to a cup ps pipe that goes back to the rack to solve this problem.
Hope that makes some kind of sense, its a much better system than that silly auto tensioner, must save a decent bit of cash come belt changing time.
Yea any pics would be great. The A/C rad has already been removed, I just need to do the rest. Really need to get the bumpers and the like off to have a good look at what needs doing. Hopefully il get it done over the winter.
Ill get a pic of everything removed for you.
Once you've removed the bumper, grill and slam panel you will easily see what's needs removed.
Been a busy day today for 596, spending most of the day on other peoples ramps. First off saw me visit Free Flow exhausts in Shotts to have my Orbisoud fitted up.
I had removed the old system a few days ago, just to save a little time on the day. Nice cherry bomb centre section there!
On the ramp being worked on.
It was then swiftly driven from Free Flow to RCA for a MOT. This is the only after pic of the exhaust i have at the mo, more to follow after a clean.
A pass, had an advisory on a track rod end needing replacing and the lambda reading was a little on the high side. Over all i'm really happy with the Orbisoud, its pretty boomy around town but sounds lovely higher up the rev range.
Last pic, also shows the half cage in the back. Wasn't a hard job to do, just fiddly getting it 100% square. Huge thanks to Fraser and John who did most of the work TBH, somthing about drilling large holes in your own car made me feel a little odd. :p
C+C welcome
Tried to get a few better pics of the exhaust, still not great tbh.
A few of the car out and about, just because I think it looks awesome.
Just seen this thread Dave good wee read! Love the exhaust was epic sounding the night I drove it
Been a busy few days with this. Nothing exciting but I'll update any way. Removed the seats, cage, carpet and foam in preperation for the next stage.
Today we spent the best part of the day removing the tar from the floor, its such a dull job which probably makes no difference but its done now.
The next thing is to get the side mounts fitted up and then in the cage and interior painted.
Rad came with the car. I think yeecup fitted that.
Cheers. It's a little low for track, and theres far far too much camber, but I'll have it sitting nice for the snow coming.
Aye I had a new radiator fitted after the old one sprung a leak
