Iron X
If you do get them sorted give them a few coats of polish and use a decent sealent, I would hope it will mean cleaning them after will be easier and save you f**king on like you're having to do at the minute.
Is iron-x worth using on bodywork? Car is fairly clean without many 'visible contaminants'.
If it is a light colour then yes, regardless if you can see them or not, they will still dull the colour significantly.
Proper decontamination of a light coloured car is very important
I thought the Trophy was clean! Bled like a biatch and the claying of the roof was fun! Like green on the clay!
Should have known looking under the roof-rails!
With IronX, I noticed it was 'bleeding' out of a load of black spots, which are obviously very easy to spot (close up) on my white car.
But it didn't actually remove them.
So is it a case of apply more, or switch to claying? (Which ill do anyway)
Probably tiny splinters of iron behind the tar etc. Can also look like Black but it's just the iron dissolving.
Thanks, looks like ill have to invest in some.
These wheels get hot, and I mean hot.
I think C5 was tested up to 500Degrees.
Work on exhausts aswell.
hit it properly first time round with an iron remover, do the prep and seal with C5. car shampoo will be enough then to remove brake dust for minimum of 6months of track use IMO. is still working on our daily car 16months on
So IronX and C5 seems to be the agreed solution then?
What about the Auto Finesse stuff on here then, any good?
Well i'd clean my wheels before using IX i'd also de-tar/clay etc before using X5. It really does have to be done properly.
Might even be worth giving your wheels to a local enthusiast if you don't want to buy each product individually.
get someone local to do it is probably your best bet. supply the c5, little bit of beer money to proper prep and seal your wheels an itll save you the full cost of all the prep products, and no fear of wrong application
ironx won't touch motorsport brake dust Tony trust me, Fairy power spray is the only thing that will (don't even have to scrub!)
Very kind of you sir. I'm away for 2 weeks anyway, from next weekend.
Maybe after my first race at Rockingham, on 6th April?
you seem to know your stuff mate....as im not your normal individual
in laymans terms would it be 1...wash car 2..iron x it 3..de clay/tar 4..wash it again 5..polish it 6..wax it 7..seal it
can this iron x only be bought online
