air con delete question
Car  clio 172 ph2
im reading the guide for the air con delete and it says i need 5 - 7mm washers? is it the hole in the middle that is 7mm? i can get 6mm and 8mm no prob but 7mm is an odd size. and also how big are the actual washers, e.g penny washers?
any help would be great!
this one?
I don't know what air con delete guide you are using tbh.
m7 is a very rare size, drill out 6mm washers if desperate.
I think the guide means depth.. As in so many washers to create a spacer so the tensioner wheel sticks out far enough. If it the guide I've read anyway. Hope this helps!
