im reading the guide for the air con delete and it says i need 5 - 7mm washers? is it the hole in the middle that is 7mm? i can get 6mm and 8mm no prob but 7mm is an odd size. and also how big are the actual washers, e.g penny washers?
I think the guide means depth.. As in so many washers to create a spacer so the tensioner wheel sticks out far enough. If it the guide I've read anyway. Hope this helps!
fook fook fook....I was looking for this thread and couldn't find it.........now i dit.
I have a belt that squeals at maximum lock....and Yes I used a 1660.........off to order a 1640 now!
