My Inferno Project (very pic heavy)
  Clio 182 FF inferno
I bought my Clio about a year ago it was March 2012, since then a lot has changed, when I bought it it was a 100% standard Full Fat 182 with both cup packs
When I bought it the exhaust looked a bit rotten and knew it would need replacing soon, I took it to The Fast Show 2012 at Santa Pod then on the way back I had a play with an RS1800 powered Ka and my exhaust shifted and started blowing like mad! I got it home and I bought an exhaust the next morning from Ktec and it arrived the morning afterwards, the exhaust I decided on after listening to loads the night before was the KTR ultra Performance SuperSport with decat
Couple weeks later my mate carbon wrapped his bonnet and boot lid on his RS1800 powered Sport Ka and with the left overs he wrapped my front badge which actually look quite alright
I then that June went to Modified Nationals 2012 on the stand for Essex Cruise Scene
When I was there I bought a piperX panel filter for my standard air box
On the way back I met a few mates down at Pitsea flyover then as I went to leave I went to start my engine and It wouldn't start an I heard a small click noise from the bay and I knew it was gona be Cambelt , and had to get it recovered back to my work place in Romford
The next morning I went down to work and took the top engine mount off to look at the top of the belt, for a second I was over the moon so happy because it hadn't snapped but then realised the belt must have jumped
Considered either just swap engine over or get the head rebuilt because I have the history of the engine and it was a very low mileage engine so I decided on the head rebuild
So then about 6 weeks later off it went to Engine Dynamics a renault engine specialist in Braintree
Once he took it all apart he see what happened, it is the most unlucky timing belt failure he had ever seen I'll upload the pics and explain it bit by bit in his words
A bolt must have been over tightened from the factory or a flaw in the bolt, it broke and somehow went upwards possibly aided by the aux belt and ended up wedged up in the exhaust can pulley, the bolt originally came from the crank seal housing
The Bolt that cause the problem
It then wedged itself in the circled area causing the belt to jump and then bent 12 valves
Also destroying my cam pulley in the progress
Andy at Engine Dynamics then fully rebuilt and refurbished my cylinder head, and done the obvious stuff like belts and pulleys, he also replaced my leaking PAS rack and I got him to put a performance map with over run on my car
August 2nd I picked the car up
then went to get it taxed and tested where it passed with flying colours ;)
That night I organised a meet at graffiti tunnel with a couple of mates :)
Then that November my gearbox went pop so I took it off the road to repair it and thought I'd change a few things 5/6 months later the gearbox has been repaired but its still off the road because instead of changing a few things I've changed a lot and spent a lot too lol haha but it due to come back on the road in a few weeks 11th of May and I'll be doing another new that night at the graffiti tunnel if anyone is up for then PM me
A few of the things I have changed(not all as I have a couple of very busy days fitting everything before its on the road
I bought a Ph1 air box(going to be painted) and a piperX filter insert for the air box
Took my inlet and other bits off to be painted
Once the grille was painted I refitted it and added a sticker to the small recess
My exhaust melted my trims so I've replaced them with carbon ones and painted the rear plastic bumped trim
Painted my dash strips and steering wheel insert
Polished my throttle body :)
Got a civic type R aerial
Black 197 style renaultsport rear sticker instead of standard badge
Rear wiper removed and sealed properly then blank fitted
Genuine Carbon front badge to replace my old wrapped one
Ordered a smaller front plate
my inlet, engine mount and throttle body was painted Crackle Black and my engine hooks and oil cap were painted satin black I fitted back to my car today along with my SFS Silicone bend
ImageUploadedByTapatalk1365455399.514802.jpgImageUploadedByTapatalk1365455414.782339.jpg
Bought some black pro race 1.2s from someone on the forum with new toyo tyres
Bought some strut braces front and rear from eBay, thought they were black but when they arrived they was anthracite so they've been painted satin black too
(Satin black pics coming soon)
Much more too come as I don't have pictures of everything yet
I'll keep this updated regularly
  Clio 182 FF inferno
Also thanks to my mate Chris at Coles Customs for some great ideas, doing the painting and helping with a lot of the fitting
jenic
Looking good but I'd change the fog surrounds back to black and put standard silver diamond on.
  Decked Dirty Diesel!
Looks good mate, where did you get that rear wiper blank?
Im just using a grommet and it doesn't look as nice as yours! :)
  Clio 182 FF inferno
I'm waiting on my carbon to be delivered next week, the body coloured ones have already been removed, I bought the car like it
  Clio 182 FF inferno
UPDATE-
Black door bullets fitted :)
Please excuse how dirty it is at the moment it's been off the road for months and needs a good clean,
Also fitting black Clio badge later today :)
Rubicon_
  L110, RS6, Westfield
For some reason I just can't stand inferno and black. I tried it a few times on mine but wasn't a fan. Nice mods and good progress though.
  Clio 182 FF inferno
Yeh you can spray it with any VHT paint doesn't have to be crackle paint I think I'm the only person on the forum to use crackle paint, mainly because its not very well known and also because it has to be painted in a particular way and then heated up a lot which makes it a pain to paint, just make sure your wire brush it an clean it up first
  Clio 182 FF inferno
UPDATE!
Bumper off so I can do a few bits,
Removing headlight washers, blanking headlight washer pipes, fitting carbon headlight washer blanks, clean bumper up, clean everything behind the bumper, change a fog light as one of mine has a crack, fit headlight carbon fog surrounds and few other little bits too
Carbon should be here tomorrow from streamline carbon
Should be back on the road in few weeks, I have a lot to do, a lot of updates coming in the next few weeks
Sounds good, I'm looking at doing the carbon washer blanks on mine, will be good to see how you do them and what they look like when done :)
  Clio 182 FF inferno
Update
Car is now on the road
Ph1 airbox on
Carbon fog lights on
Carbon washer blanks on
New splitter was short lived but here you go
Lowered on cooksports
Carbon rear badge fitted
Couple of random pictures
Brembo HC's
Roll cage and rear strut brace fitted :)
  Clio 182 FF inferno
Sounds better than the standard airbox mate and about the splitter tbh a lot of people loved it and a lot of people weren't a fan also, it looked 100x better in person I only removed it as once it was lowered it was only an inch from the ground and it scrubbed on everything and it really annoyed me so I'm putting my standard cup splitter back on
Jekyll
Have you got a guide to what you did and parts you used to remove the old headlight washers and fit blanks. I've bought some off here and ill be spraying and bonding them into my bumper like you have done.
​Car looks good too :) Like that front splitter a lot but you can see why it didnt last long!
  Clio 182 FF inferno
Sorry I haven't but its really easy you need to remove the bumper which is 2 clips at top of grill(flat head screw driver), 2 10mm bolts under the arch liner in the top corner of the bumper(1 each side), few torx screws underneath and at the side of the bumper(1 at each side and then I think 2 on the bottom each side) and 2 10mm bolts on the black bit underneath too then pull the bumper each side away from the wing it's 3 Clips you'll hear undo themselves, once that's done dont pull the bumper too far you have to disconnect the fog lights which is one plug on the passenger side then pull the bumper away and pull the hoses off the washer jets and out of bumper and undo the back of the washer jet with I think it was a 20mm spanner and they come straight off, then what I done with the hose was when the bumper was off you can see right in the corner near the Passenger side wheel where the 2 hoses have joins in them, I removed all the hose up to there then connected them to each other with a small cut off bit of tube from what I'd removed, it's really simple when you have bumper off, a lot easier then you would think, when you do it if you get stuck send me a message and I'll draw a picture up for you
  Clio 182 FF inferno
Thanks mate, the splitter has a lot of haters but a lot of people liked it too, it was different because nobody has tired it to a mk2 Clio before everyone who actually see it in person absolutely loved it,
Jekyll
Thanks for that. I know how to get the bumper off so I was just wandering what you did with regards to removing the jets and hoses afterwards, etc. looks so much better with the blanks fitted and no more steaks!
Yeah the splitter is quite different but cool. It is very chunky though and if your low then it always be a no go! Lol. Have you thought about dropping Chris Powell/Carbon Central in the traders section as he can skin over your cup splitter in 2x2 twill carbon. It would be stronger and match your fogs and blanks nicely :)
Yosemite Sam
  Whichever has fuel
That front splitter look(ed?) like the rear spoiler from a Capri Laser.
​Apart from that, I love it. :D
