Titanium 182 FF
I am a bit worried about the Clio at the moment ![Frown :( :(](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Here are the symptoms:
- Key in, wait for the lights to extinguish, try to start and it just cranks over.
- If I remove the key, close the door, lock and unlock and then try again the engine will start up straight away 90% of the time. When the Engine is idling and running it sounds and runs as you would expect.
- It cuts out randomly. This morning around a roundabout, no warning lamps nothing it just died. I went for the Hazard switch but it did nothing. Third attempt at restarting and the engine started and I continued to work.
- There are no trouble codes that I could recover.
Background
- Car has a factory alarm fitted
- The other weekend when using Cruise Control on the Motorway everytime I used the RH indicator it would turn Cruise Control off, possible related issue??
Any help at all would be greatly appreciated!
Mat
Background
Mat
