Front washers not spraying?
The_Pirate
Car  Golf R
Hi guys, having an issue with the front water sprayer. Now this seems to come and go, when pulling on the stalk the rear washer goes? The pump is obviously going but not spraying the front, just the rear???
What could be wrong? I've heard this could possibly be early signs of UCH failure? It would seem there is a dodgy connection somewhere if the rear is going and the front isn't?!?
As usual i appreciate any help!
You need to look at the guide for this & headlight washer jets mate.
Although to be honest if the pump is dead, you're probs best off just buying another one (they are £13 from GSF) instead of messing about with the one you have as suggested on here, that is a waste of time.
If the pump is running check that the hose that runs down the bonnet/hinge isn't kinked when the bonnet is shut.
Sorry mate should have said its a Cup and its the washers for the windscreen not the headlamps - the pump is working (from what i can hear)
Filter mesh on the pump could be blocked (cant remember if clios have it) or the jets are blocked, take it to a garage and ask them to give the jets a blast with an air line, with the pipes off the jets, also while the pipes are off give the stalk a pull to try clear some of the crap out the pipes...
does the pipe not run from the bottle, up the passenger bonnet hinge, then across the bonnet to the jets?
Right this is weird, the water was spraying on the rear window when pulling the stalk, it started running low so put more water in it and now its working again?!?
f**k YOU FRENCH CAR.
Has it been doing it for long? Maybe there wasnt enough fluid in it?
My work van comes and goes when the fluid is low. Works one time but not the next
Hi Danny,
I had same trouble with my 182?! The amount of crap in washer bottle was unreal like black sticky stuff??
So put compressor on and blast down jets on bonnet back onto bottle and cleaned as much black rubbish out of bottle?!
Syphen water out bottle and wipeout bottle has best you can?? long screw driver with rag on bottom to wipe bottle out
Few more blasts of air down jets nother wipe round n bob youre uncle washers working again :clap:
Then go straight to fridge for celebratory drink :cheers:
Hope this helps
Cheers Pat
Haha, Cheers Pat i'll give that a go tomorrow then! Its bizarre how the rear washer would operate if there was something stuck somewhere? Also odd that pulling the stalk activated it also??
Sorry bit long winded but you get the drift ;) water was purapse finding easy way out??
Hmm, i see what you're saying. I suppose if it were blocked somewhere the pressure would force it out any which way it could manage?
Well hopefully i disturbed something enough to make it last lol.
If the bottle has gunk in it just remove it and put it in a dishwasher - mrs might not like it but it works a treat. Then blow the pipes out with an airline, just to be sure there is nothing blocking them before refitting the bottle.
