Danith's Clio RS 220 Trophy ph2
Danith
  MX5 ND2/220 Trophy
now change the leds on it :)
Had a look, looks way too fiddly for me. Think the last time I used a soldering iron was gcse tech.
Don't mind the blue tbh. @Adey. Will give it a go I'm sure
massiveCoRbyn
  Several
It's stupid in a way, but I think bits like the Brembos make the car way more desirable. It makes it look and feel more special. If these had come with more bits like that from the factory, they would have had more appeal IMO.
That said, as they get older, I do like them more.
Danith
  MX5 ND2/220 Trophy
yeah the Mk3 200 is still for me, the best one. Brembos, Snazzy speedline wheels, those arch vents and recaros.
  2014 Clio 200t edc
I’m sure I read somewhere that renaultsport had the engine from Nissan but spent all the rest (or most) of the budget on the gearbox which is why everything is pretty standard with regards to brakes, seats etc.
the brakes aren’t bad as standard but as you say some special bits would’ve made it a better package. Especially when the vxr corsa and fiesta st had recaro seats etc.
massiveCoRbyn
  Several
Yeah it's just superficial really as, in reality, they handle and stop perfectly well. It's just the "cool" factor of having bits that make the car feel a bit more bespoke.
Danith
  MX5 ND2/220 Trophy
@Danith i know the cars up for sale so may not been given too many miles, but could you give an honest review of swapping to the brembos?
Honestly, yeah out of 4 cars now I've done a brembo swap in only 2 have been worth it, the skoda and this one. Just feel more sharp, not a huge improvement, but then they look miles better, are lighter (not that it matters on a car with a heavy front end 😂) and loads more choice of pads.
Worth doing if can get the calipers for cheap
Danith
  MX5 ND2/220 Trophy
You might have seen I put the clio up for sale a while ago. One of those 'feeler' posts I guess as I just got bored of the whole modifying thing and fancied something more luxury.
No rush to sell though, the hassle still ramps up my anxiety.
I've taken a couple of the mods off now - k and n panel, forge hose kit. And never bothered with the airtec cold side pipework or silicone intake hose. All been sold on.
Almost forgot I'd dropped off a steering wheel and the gearknob cover off with @snappy back in Feb.
Got the message off him a few weeks ago it was done and he sent it out to me.
Done loads of cars up til now and all been pretty easy. This car tho, jeez getting the airbag off is a pain in the ass. And the airbag wire is unbelievably fragile. So that snapped when I eventually managed to get the airbag free and I got a cob/panic on and used the twingo til I could find a replacement squib.
Fun thing with the squib is that the part is specific to a phase 2 facelift trophy as its got the fogs and there's a 30% shorter throw in the trophy paddles - wasn't sure how until I compared a used cup one I managed to get sent over from a guy in Holland 😂 was a lot cheaper than any UK breakers, who all only had preface cup ones. So I took a gamble on this lhd, preface, cup version.
Anyway, after dismantling all the bits off the 2 squibs - paddles, stalks, steering angle sensor, multimedia stalk and (most importantly - after a working airbag wire of course) found I was able to swap the gear change components to keep the shorter trophy throw.
Amazingly this hyped up trophy revision isn't achieved by snazzy paddles or a reworked mech, but just a 2mm notch added to the paddle switch platforms 😂
You can definitely feel the difference though so I braved it and went ahead to work out how to remove and swap them without damaging anything.
So result, fixed. And now have a much nicer, less sticky, Alcantara and proper leather steering wheel, with matching gearknob in Alcantara.
Brigsy
  T.Turbo
Steering wheel looks great. Pain about the squib, they are super fragile. I hate removing ren airbags for that reason as easily damaged.
Danith
  MX5 ND2/220 Trophy
Took the powerflex inserts out of the main engine mount and upper gearbox mount. Must be getting old.
Preferring the car stock tbh. No plans to map, lower, make louder or put any massive spoilers on. Brembos are a good touch, as are the stud and nut conversion and silver rims.
Booked goodwood in July, torn as to whether to take this or the mx5.
Still loving the yellow, especially on the motorway full of monotone German barges (if I have the tunes on to mask the interior rattles 😂)
Danith
  MX5 ND2/220 Trophy
Summer's here! So what does the Clio decide to do? Delete the ac, again. Nice one.
No codes this time. Assumed a leak or dodgy pressure switch. Anyway got it booked in with an ac specialist near me I've used before (top bloke for anyone in St Helens area BTW, called Cool Wheels).
Pressure fine, refrigerant gas ok, no codes, just another mystery.
Then he got it on the ramps and went to test the compressor and relays and the lovely sound of 'click' from the clutch, followed by ice cold air.
Thank eff for that. Loose plug connection to the compressor.
Daz.
  Clio 200 RS EDC
Wish my ac would just be bloody consistent, never had such a random issue with a car!
Daz.
  Clio 200 RS EDC
Just decides it doesn't want to play ball at certain temps.
If it's 28 degrees outside it's happy, same for cooler temps.
But if it's say 20 degrees it goes naaaaaa...
But then after 5-6 mins it goes ok I'll play your game 😂
Danith
  MX5 ND2/220 Trophy
Yeah that's a Renault alright.
Matt Cup
  Leon Cupra
Nice. Was a good turnout and no massive queue this year.
I didn't stay too long had to get home for 1. Seemed to get busier as was leaving too
Yeah it was decent, seemed to be a bit of a McLaren owners club meet in the morning but still plenty of other more interesting cars turned up later on.
We got there about 9:45 and left at around 3, was really busy around midday.
Danith
  MX5 ND2/220 Trophy
Yeah loads of mclarens. That chevy nova hot rod drag car looked spicy. I left at 11.30 and loads were coming in. Will stay longer next time.
Loved the battered looking nova sr at the side by the toilets, next to the brand new m2 thing.
Matt Cup
  Leon Cupra
Yeah that Chevy was a bit naughty. It’s something you expect to see on street outlaws not at a cars and coffee in Yorkshire. Suppose it’s the beauty of that venue as it has all sorts attending.
Did you see the black Ferrari 328 on air ride?
Danith
  MX5 ND2/220 Trophy
Used squib lasted 1 month :LOL: was worth a try for 40 quid. Took it apart and looks like it's been effed about with previously and someone did a crap job of putting it back together - they're super fiddly so not surprised. Basically it's wrapped around itself and eventually snapped where it joins the spool.
Thought about using another used one as Renault RRP is £390 for new! But decided to just bite the bullet and got one from RPD and yep, you guessed it, it was on back order. Only 2 weeks, so got it this week and fitted it on. All good again, I have no airbag light and working cruise.
Expensive lesson/steering wheel retrim that was :ROFLMAO:
Part number for a Trophy (shorter shift switches) is 25 56 726 71R in case anyone needs one. Comes with paddles but no stalks, audio control or steering angle sensor.
